Rda Rotor (& Ebc Pads) Group Buy Is Back In 2008!
All Group Buy 37 orders confirmed:
- Samstain (payment cleared - waiting on delivery address confirmation)
- GTS-T Sedan (payment cleared)
- 33drifter (payment cleared)
- SirSkyline (payment cleared)
- phunky_monkey (payment cleared)
- pw350gt (payment cleared)
Closing tonight.
  • Replies 548
Posted Images
Group Buy 37 is now closed:
- Samstain (payment cleared)
PMs replied, others that miss out don't despair - will be in the next group buy
Hello again Rianto,
I though I was suppose to be on this group buy....
Does not matter.
Could I please go on the next one for rear slotted rotors GTR33..thanks
No problems, if you still have the quote pm, just send the payment and I'll put you in the next one closing 5th October..
Also there's slight delay with Group Buy 37 orders below:
At this moment my contact @ RDA is away for 2 days, but he'll be back and sort it out as soon as he's back in office.
Will advise ASAP when they send group buy 37 orders out of their warehouse.
payment made for the 280mm gold slotted/dimpled front+rear. payment reference is "chad sau rotors". i have sent you pm for my delivery details. thankx
Just found out this morning that after 5 days in the server queue my email for the order didn't get through again, just like last month. Tried sending via hotmail, TPG, and uecomm (work ISP) and nothing goes through. Apparently I have to do it by fax. Will fax it tonight, my contact should be back from his holiday tomorrow and should be able to process it.
Update 8:15pm - Finally resorted to fax method, group buy 37 has now been faxed to RDA. I should normally hear back from them tomorrow.
Sorry for the delay.
Next Group Buy 38 orders:
- Chad_ (payment clears)
- 700HP-GTR33 (waiting for payment)
- R34GTFOUR (waiting for payment to clear)
- NIC334 (waiting confirmation)
- Chad_ (payment cleared)
- R34GTFOUR (payment cleared)
Any news on group 37 dispatch yet??
Just spoke to my contact @ RDA, he'll be back at work in a couple of days. There's a little bit short on shipment of stock so at this stage looks like Group Buy 37 will be shipped out around the end of this week. Sorry for any delays caused.
- 700HP-GTR33 (payment cleared)
- R33_ACT (payment cleared)
- Smity42 (payment cleared)
- scotty32 (payment cleared)
- namekemono_dori (payment cleared)
Closing this weekend!
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
    • More so GReddy oil relocation kits, sandwich plates, etc. all use 10AN fittings. And same, I've only used 10AN and my car sees track work (circuit, doing laps, not 10 sec squirt business).
