I'm at 74/5kg and 10%BF. I was stuck at 72kg for a while but have started making better progress this time around. I'm probably not going about this the same way as everybody else, I'm gaining muscle mass and and at the same time keeping lean the whole time. Diet only, no supplements, although I'll be going on some protein soon but that will be about all.
I've gone from 70kg to 77kg to 85kg but gained a fair bit of fat from bad dieting while training, I stopped training and dropped my weight down to 70-72 and started training again. So far I've gained 2-3kg and dropped body fat in the process..... I'm doing it over again with a better diet and it's working a lot better for me this time.
  • 3 weeks later...
had my 4week measurements done and weighed in 3kg lighter, arms, legs, glutes and chest are bigger, waist is 1.5" smaller and shoulders have gone a bit smaller (holding fat in left shoulder) have comparison back double bi pics will post up later tonight.
Diet are training are pretty much spot on, havnt lost any strength through dieting at all.
Forgot all about this thread lol. I just got back from Melbourne this weekend so the last 2 weeks the training was a little off, I did hit the gym but yeah wasn't dieting at all. Started my dieting this week so yeah hopefully nothing else gets in the way and I can keep at it and go hard !
Since this is a suppliment thingo I thought I might add what is the greenline or nengun of suppliment sites;
www.professionalwhey.com.au
I haven't found a cheaper place to source WPI. They get the stuff from the only source for quality WPI in the southern hemisphere Fontera's factory in NZ.
Hope that helps. :happy:
Another tip for those who might be looking a tribulus and a variety of other so-called natural hormone boosters;
Most of these snake oils have zinc, manganese and B6 added. These are actually the ONLY active ingredients. There is plenty of data around these nutrients and theraputic ratios. When you weight train and as you get older you need more zinc for hormone production boost.
Cenovis Zinc plus is about $6 for 100 tablets from woolies. Works a treat. :blink:
aldi spec protein store lol.. good to see the "no frills" stuff..
one thing that gets me is.. why would someone under the age of 25 want test boosters? nothing (apart from actual test) will work for you unless you are actually low on test. Waste of time and money.
Hope that helps. :devil:
Cenovis Zinc plus is about $6 for 100 tablets from woolies. Works a treat. :P
So you add Magnesium and B6 with those Zinc tabs?
When do you take the Zinc tabs?
    • Yes the gear for the R33/34 is different, it is red and has a different number of teeth. My part didn't come with that gear though, so I don't know how many teeth are on the red one. You'd have to reuse the 260RS/R33 gear, as long as it's not destroyed.   Haha, as unfortunate as that might be it was working fine for about the first 1500km I've had the car for now.
    • Update all   thanks to the workshop manual, it lead me back to checking fuses as mentioned central locking and door open lights worked when acc was switched on. diagram attached shows two points of power 1. ACC and 2.  Batt with the later being fused (#28) I did check the fuses using a multimeter but I must have stuffed that up also. Went back and checked the batt fuse in interior fuse box and you wouldn’t believe it… a blown fuse. replaced fuse and everything is now working as it should including the climate control   thank you all with your positive insight and knowledge.
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
