Yer I'm on a protein break in favour of alot of cardio and trimming. I've trimmed almost as much as I should but I'm kind of reluctant to get back on the bulk because I liked the toned look lol.
You can never win man. Tone vs Bulk.....just try and get bigger/leaner over time I guess.
My friends, when I bulk:
'Hey man...you're HUGE, but you used to be way more cut up."
My friends, when I cut:
'Hey man, you're more cut now......but you used to be huge!'
Hahaha it's so true. A happy medium is probably where it's at. Man I hate withdrawals after missing gym for a week or two, you feel so untoned. Then you go and ask someone if you look smaller and they say you look the same as you always do :blush:
lol u gotta cop that straight on the chin....seriously u just cant reply to those remarks LOL
Hahaha it's so true. A happy medium is probably where it's at. Man I hate withdrawals after missing gym for a week or two, you feel so untoned. Then you go and ask someone if you look smaller and they say you look the same as you always do :D
I agree, I am going to settle for my 'lean' being at around 12-13% bodyfat, I want to look big in clothes, not only in singlet/tops off.
haha I just laugh man.
Do my own thing, at the end of the day, I do it for myself.
I've sort of been forced into a cut though, due to Ramadan. Ideally would have liked to bulk for another month, but oh well.
chill as
ne ways im 18 started doing some home gym stuff bout 2weeks ago now
i weigh 97kg's probs with 25kg's of fat i would say 6ft tall
freeweight benchpress started doing 90kg now after 2 weeks doing 110kg( 2reps) also 9reps on 90kg
tripress 150lbs(68kg) 15 reps
and 28kg DB bicept curl 4reps at max
my goals after four months are to bench 130-140kg's 3-4reps, bicept curl 30kg 10reps, close grip bench press 90kg 4reps
so far doing gym everyday mixing it up once a week with some super sets on tricepts and chest muscles bout 40mins-60mins a day
going to start cutting down on food and hopefully get down to 90kg's not needing to get super thin just gotta lose the bitch tits( shy muscle)
also im traning for boxing so yea looking for a strong solid punch( which is why buildig up tricept a fair amount)
any comments on excerices for triceps or tips to lose that weight
or anything to ask me in genral go for it
never going to lift anything past my shoulders as i know it f**ks them up hardcore
have no real need for those three things. unless i was trying to sculpter my body like a body builder other wise im just getting bigger for boxing
also dont have enough weights at home to do squats or dead lifts
either way mainly focusing on tricepts, bicepts chest and lats
even if you feel that you don't need legs and so on, squats and deadlifts expend a huge amount of energy which will help you burn that fat off a lot quicker. Plus the extra core strength you will get from them will definitely hell with your boxing....
Edited by JKR-32
chill as
110kg bench if your doing it properly after just 2 weeks training is impressive lol
    • Perfect, I'll get to it this winter then at the same time as I weld on my anti squat kit.
    • Alright so my 32 only has one temperature no matter what degree you set it to. I’ve tried disconnecting the servo motor arm and moving it either direction and got no change. I’ve fixed the leak in my AC and re charged it and with it on and clutch engaged it still blows hot even though the low pressure pipe going to the firewall is ice cold. Both heater core hoses are hot while running as well. Diagnostic code showed 24 for intake air temperature sensor. Anybody got any ideas?
    • I said Garrett style. Not Garrett genuine. And something in the G30 550 range is what you want. Not those pokey little old fashioned T28 sized things. The intake ports in the head are small. There is little benefit in fattening up the runners and leaving ths actual ports small. Just run what you've got. And on the subject of Nistune vs Haltech etc..... You know you can control the transmission with decent standalone ECUs these days, right? No need to keep any of that old Nissan bullshit. Don't get me wrong - I use Nistune on my Neo. But it is a DET, so the number of bodges and workarounds I had to do to make it work in a chassis without ABS, TCS, etc, is quite small compared to the herniated arsehole you will have trying to make it work on a motor that doesn't have some of the things that the turbo ECU wants to see. Just easier to bite the bullet and go aftermarket outright.
    • Hmm. Only when the f**king thing is actually working. Still can't find the leak. And that's with dye being put in the last 3 times!
