I had an interesting discussion about cheat meals recently.
Many people see them as an out for people who simply cannot strictly diet.
This isn't true, in fact, cheat meals serve a key purpose (or a dual purpose):
1: They trick your body into thinking that it is getting ample nutrients/calories, therefore, your body is less likely to go into starvation mode and do its absolute best to hold onto fat stores.
2: They keep you sane/more likely to stick to your diet and can be motivating. I especially look forward to my cheat meals whilst cutting.
Cheat meals are the safer option when compared to 'cheat days', you risk binging too hard on a cheat day lol. But if you can keep it within reason and it works, why not?
good news... I was undecided on going to dinner tonight as I know it will be a massive eat fest... and a few beers will get consumed no doubt
Budapest in Elsternwick... great Hungarian food but massive portions and when its in front of me I just keep eating lol... so I'm trying to eat very light today in preparation
been making good progress lately, slowly cutting back for summer... I've tried last minute cuts before and its always been a failure... I don't function very well when I haven't had enough to eat, I get grumpy and have crap workouts so still trying to find the best balance
lol at Jay Cutler... he really is a freak... I read that in the first year he took up BB'ing he put on about 20kg of muscle! (can't remember exact number but it was ridiculous)
epic meal time you say?
Ye it has good effect on metabolism and serves to give the body a bit of a kick.
Plus one huge gorge/cheat meal isn't really going to alter the weeks diet much at all.
I'll ask the dude @ work if i can chuck up some of his pics - strict as 40yo with diet etc. He gives himself 1hr per week to "go nuts" and eat anything and everything (like 1 large pizza, 3 icecream cones and maybe 2-3 cans of coke) except when prepping for a comp. Says it hasnt affected him at all and is a good 'break'.
I got a SKINS top and it does a good job of keeping the chill out when running cold winter nights...without restricting breathing. Beats ye olde topless running and hypothermia.
u funny flamin mongrel..nah no nigerian but mostly vids posted from U.S.
i bit the bullet and got it from uncle Torrence the whole 12 vids it seems ok i guess but i aint game enough posting vids of my progress as i know i'll give up soon..im snacking on burger rings as im typing this post
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
    • I've got MCA Blues on my V36 Skyline, and while I've managed to sort out issues with scrubbing/bottoming out by raising it a smidge and increasing the damping hardness, the rear end still sounds *super* noisy when driving on anything other than the flattest surface imaginable. It sounds like a small party of flamingos are just chatting away in the back, which makes me think there are several link points in the suspension contributing to the noise. Am I hearing dried out/worn bushings? None of it sounds like metal-on-metal, it sounds more like hard rubber squeaking on metal. It's been suggested that a bit of silicon spray on each bushing might quiet them down, but I'm not sure what material the current bushings are made of (probably factory, I imagine) and whether silicon spray will degrade that material.
    • The obvious answer here is get a ND2/3 RF with the Targa top. The red is nicer, too!
