I just stick to Dymatize Elite.
Tastes great, easy to get, enough protein in there and so on.
CBS risking buying poor tasting protein in bulk and then being stuck with it.
I'll give you some of mine if you wanna risk it ya girl :D
Define quick lol?
Did you get calcium caseinate or micellar casein? Usually the casein taste extra gunky and like crap.
calcium caseinate
Within a few minutes should be fine...Last night when I had it for the first time I put it in water on it's own first to taste it without adding chocolate WPI...It's drinkable on it's own, flavorless for the most part. I threw a scoop of WPI in after that and drank it straight away.
This morning I mixed it up and put it in the fridge for maybe 15minutes before leaving for work...When I started drinking it I tasted a hard piece and thought it just didn't mix, so I shook it, and noticed white hard pieces settle on the bottom... So yeah, drink it straight after you add the water and it should be fine
Why did you opt for the calcium caseinate over the miceller casein?
Ahh I didn't realise that it is flavourless! I guess i could mix in some Dymatize for flavour.
Not sure to be honest, it's the first time I've ever bought casein and they both seem to be the same reading the description, only the calcium caseinate has a higher protein %
Haha yeah I was trying to work that out myself. I was like the description is the same...yet they are different somehow.
Thanks for the advice, I'll try it out and see how I go.
Nothing worse than chewing on chunks of protein clumped together or sticking in your throat. Shit becomes like chewing gum. Think I'll invest in a blender when I start taking protein again.
Chunks of unmixed powder are one thing, this was solidified chunks, like a plastic texture...
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
