Anybody recommend somewhere online to get a dips belt (to hang weights from)? Planet Max here in Canberra is only place I've checked, and the only one they stock is $59 (probs ok, but steep until I know what's average)
sounds reasonable
i'd be more interested to know where you can get chains like these
I found some chains here:
http://www.gymdirect.com.au/product-search-result.htm
But you would be bankrupt (and amazingly strong) by the time you looked like your above post.
if you want chains just go to your local boat shop, or even a fishing shop. you can get some pretty decent size chains (anchor chain, they sell it by the metre and it's cheap), and they are usually glavanised so sweat shouldn't be an issue rusting them, LOL.
still not a bad investment considering you can use em for dips, curls etc
Ehh if you reckon that's reasonable then fair enough, tomorrow ill grab one ;)
here you go http://www.worldfitness.com.au/product_info.php?products_id=557 seems to be the running cost for em
hmmm hadn't thought of that...
i've checked out hardware stores only but they don't really have the right size/weight
you just need a weight belt and a short length of chain or rope... better than chains IMO as you can hang different size plates from it and be pretty specific about what weight your lifting... you also don't have to lug weight to and from the gym just a belt
then you can use the weight belt for squats/deads etc... if you just get a dip belt you can really only use it for dips/pull ups
So you reckon get a support belt or whatever they are (for heavy lifts) and then just hang a rope from that with the plates on it? hmm, double use I suppose.
I meant the exact type of thing someone linked in response to me - the belt with chain that you hang plates from anyway. It only has a single use though, doesn't provide support if I wanted to use it with deadlifts or something
Either way, I'm gonna rock on over to planet max today and see what I'll get
http://shop.ebay.com.au/?_from=R40&_trksid=p3907.m570.l1313&_nkw=weight+dip+belt&_sacat=See-All-Categories
$20-$30
But I'd be going with Nick's idea...don't see the point in having a different belt just for that when a normal belt with a chain will do the same thing
I just put them between my thighs and lock my ankles..
inb4thatswutshesaid
I always wanted a belt, but couldnt justify spending $x for one excercise. Now I do multiple excercises which could utilise a belt, but still couldnt justify.. lol.
[/quote
arent u a clever boy! lol wish i thought of that before i brought my dips belt now... i got a leather one on ebay i do like it though and get alot of use..
how many of u guys actually use a weight belt for deadlifts and squats for your back our of curiosity? and how much weight would you want to be able to dead lift before using one do you think?
I can't claim the idea, there is a weight belt at my gym setup like that... I only use the belt for weighted dips/pull ups... I have never used a belt for squats/deads etc
no idea when you should look at using one... I'm still under 200% bodyweight on those lifts so not sure I need to use one yet... and I don't do 1rm
I went to the gym at lunch today, gym is too packed after work... think I'm going to make lunch sessions a regular thing... I can't get up early enough to go before work lol
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
