Anybody recommend somewhere online to get a dips belt (to hang weights from)? Planet Max here in Canberra is only place I've checked, and the only one they stock is $59 (probs ok, but steep until I know what's average)
sounds reasonable
i'd be more interested to know where you can get chains like these
I found some chains here:
http://www.gymdirect.com.au/product-search-result.htm
But you would be bankrupt (and amazingly strong) by the time you looked like your above post.
if you want chains just go to your local boat shop, or even a fishing shop. you can get some pretty decent size chains (anchor chain, they sell it by the metre and it's cheap), and they are usually glavanised so sweat shouldn't be an issue rusting them, LOL.
still not a bad investment considering you can use em for dips, curls etc
Ehh if you reckon that's reasonable then fair enough, tomorrow ill grab one ;)
here you go http://www.worldfitness.com.au/product_info.php?products_id=557 seems to be the running cost for em
hmmm hadn't thought of that...
i've checked out hardware stores only but they don't really have the right size/weight
you just need a weight belt and a short length of chain or rope... better than chains IMO as you can hang different size plates from it and be pretty specific about what weight your lifting... you also don't have to lug weight to and from the gym just a belt
then you can use the weight belt for squats/deads etc... if you just get a dip belt you can really only use it for dips/pull ups
So you reckon get a support belt or whatever they are (for heavy lifts) and then just hang a rope from that with the plates on it? hmm, double use I suppose.
I meant the exact type of thing someone linked in response to me - the belt with chain that you hang plates from anyway. It only has a single use though, doesn't provide support if I wanted to use it with deadlifts or something
Either way, I'm gonna rock on over to planet max today and see what I'll get
http://shop.ebay.com.au/?_from=R40&_trksid=p3907.m570.l1313&_nkw=weight+dip+belt&_sacat=See-All-Categories
$20-$30
But I'd be going with Nick's idea...don't see the point in having a different belt just for that when a normal belt with a chain will do the same thing
I just put them between my thighs and lock my ankles..
inb4thatswutshesaid
I always wanted a belt, but couldnt justify spending $x for one excercise. Now I do multiple excercises which could utilise a belt, but still couldnt justify.. lol.
[/quote
arent u a clever boy! lol wish i thought of that before i brought my dips belt now... i got a leather one on ebay i do like it though and get alot of use..
how many of u guys actually use a weight belt for deadlifts and squats for your back our of curiosity? and how much weight would you want to be able to dead lift before using one do you think?
I can't claim the idea, there is a weight belt at my gym setup like that... I only use the belt for weighted dips/pull ups... I have never used a belt for squats/deads etc
no idea when you should look at using one... I'm still under 200% bodyweight on those lifts so not sure I need to use one yet... and I don't do 1rm
I went to the gym at lunch today, gym is too packed after work... think I'm going to make lunch sessions a regular thing... I can't get up early enough to go before work lol
    • I neglected to respond to this previously. Get it up to 100 psi, and then you'll be OK.
    • I agree with everything else, except (and I'm rethinking this as it wasn't setup how my brain first though) if the sensor is at the end of a hose which is how it has been recommended to isolate it from vibrations, then if that line had a small hole in, I could foresee potentially (not a fluid dynamic specialist) the ability for it to see a lower pressure at the sensor. But thinking through, said sensor was in the actual block, HOWEVER it was also the sensor itself that broke, so oil pressure may not have been fully reaching the sensor still. So I'm still in my same theory.   However, I 100% would be saying COOL THE OIL DOWN if it's at 125c. That would be an epic concern of mine.   Im now thinking as you did Brad that the knock detection is likely due to the bearings giving a bit more noise as pressure dropped away. Kinkstah, drop your oil, and get a sample of it (as you're draining it) and send it off for analysis.
    • I myself AM TOTALLY UNPREPARED TO BELIEVE that the load is higher on the track than on the dyno. If it is not happening on the dyno, I cannot see it happening on the track. The difference you are seeing is because it is hot on the track, and I am pretty sure your tuner is not belting the crap out of it on teh dyno when it starts to get hot. The only way that being hot on the track can lead to real ping, that I can think of, is if you are getting more oil (from mist in the inlet tract, or going up past the oil control rings) reducing the effective octane rating of the fuel and causing ping that way. Yeah, nah. Look at this graph which I will helpfully show you zoomed back in. As an engineer, I look at the difference in viscocity at (in your case, 125°C) and say "they're all the same number". Even though those lines are not completely collapsed down onto each other, the oil grades you are talking about (40, 50 and 60) are teh top three lines (150, 220 and 320) and as far as I am concerned, there is not enough difference between them at that temperature to be meaningful. The viscosity of 60 at 125°C is teh same as 40 at 100°C. You should not operate it under high load at high temperature. That is purely because the only way they can achieve their emissions numbers is with thin-arse oil in it, so they have to tell you to put thin oil in it for the street. They know that no-one can drive the car & engine hard enough on the street to reach the operating regime that demands the actual correct oil that the engine needs on the track. And so they tell you to put that oil in for the track. Find a way to get more air into it, or, more likely, out of it. Or add a water spray for when it's hot. Or something.   As to the leak --- a small leak that cannot cause near catastrophic volume loss in a few seconds cannot cause a low pressure condition in the engine. If the leak is large enough to drop oil pressure, then you will only get one or two shots at it before the sump is drained.
    • So..... it's going to be a heater hose or other coolant hose at the rear of the head/plenum. Or it's going to be one of the welch plugs on the back of the motor, which is a motor out thing to fix.
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
