Some more protein from Bulk Nutrients turned up for me today. Got myself 4kg of vanilla and 1kg of banana (I ordered 5kg of vanilla and asked if they could sub 1kg out for 1kg of banana :D). So far the vanilla is exactly as I expected - really tasty. It's a subtle vanilla taste, like you'd just put a heap of essence into milk. As always, mixes with absolute ease.
Can't wait to taste the banana though :D
Re: bulk nutrients
Bought 1kg of chocolate micellar - tastes watered down compared to the normal chocolate WPI
1KG of vanilla wpi - tastes great.
5kg of chocolate mint - rubbish. Tastes like a chocolate shake after u brush your teeth.
FFFUUUUUUU!
^Correction: Optimum Nutrition 100% Whey Gold Standard
I bought a 2.2kg tub of this last week for the first time. I got Extreme Milk Chocolate, taste's OK I guess...but the BCAA's and Glutamine profile they put in it make's up for it :thumbsup:
Deadlifts now slotting in as a favourite exercise...feels good man. Hamstring/inner leg cramps = not so lol.
I feel the same brah. Deadlifts are win, hardly being able to walk or stand up straight for the next few hours is a little less than win...well, it certainly doesn't feel like win.
Haha my legs are f**ked today, but it feels great knowing I've activated a lot of muscle that I normally don't. Now just need to get back into the squats and I'll be set, no more chicken legs.
Try having to ride home afterwards! it's about a 3 minute chillaxed ride to my gym, nice and flat all the way.....then on the way home after legs it's like WHAT THE f**kKKK
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
