I've made phenomenal gains by pretending to go to the gym and throwing out my e-stats online.
My BN experience has only come about 4 weeks prior to Christmas.. and I've been using BN protein (whey/casien) for the past 6 months. So I'm surprised as anyone else.
So far this week I've dropped BN, still 'bloaty-ish' but will keep an eye on any changes. Tell you what.. Syntrax Matrix - Cookies and Cream.. best. ever.
Serious question...
Have been doing deadlifts for about 2 months now. I started low in weight (10x60kg) just to get technique downpat, but have since worked my way up to 10x80kg, 10x90kg and 9x100kg. Here's my problem: back wants to keep going, grip is slipping, hence the 9 reps.
It's probably more reps than most people do for deadlifts, I know it's supposed to be a low volume / high weight exercise, but I'm somewhat obsessive about 10 reps for most exercises. Still, these aren't huge weights so I should be able to crank them out. Potential setbacks I can think of:
- I use a pronated grip, I'm most comfortable with this and I'd prefer not to use a mixed grip if I can avoid it. Just doesn't feel "right" to me.
- I wear gloves...again, prefer to keep this. Skin is friggen soft so my calluses get out of control if I don't :(
- Deadlifts are performed at the end of my "pull" day, which is a grip intensive workout...consequently by the time I get to deadlifts, my fingers/hands are worn from pulldown, rows, cables etc. It's a back intensive day too, which is why I stick deadlifts at the end, cause I don't want to wear out my back too early and be screwed for the rest. But again, back wants to keep going, it's grip that's the issue.
Suggestions on how to improve grip? Will my grip improve with forearm strength over time, i.e. am I expecting too much too quickly from deads?
Do grip strength excersies, mixed grip or hook grip. Gloves will be hindering your grip too.
I personally use hook grip which can be painful if you're not used to it.
Also, you should do deadlifts first on back day.
Edited by KezR33
Serious question...
Firstly, Nancy, calluses are manly....lol kidding :P
I too find this to be the case to some degree - just can't hold on long enough to really work the back, though I use alternate grip (one hand facing forward, one back) and just try to swap each set. With deadlifts and squats I will still use the same set structure as you with your exercises - 60kg x2, 90kg x2, 120kg x2. Since I'm doing 2 sets of each weight, I swap my grip each time. Makes things feel a bit more even.
Though I would perhaps suggest inward wrist curls (whatever they'd be technically called) with a barbell on a bench for forearm strength. I assume that would assist with grip strength...I honestly have no idea :P
1. Don't use gloves for deadlifts
2. Don't do deadlifts at the end, do them at the start with proper warm-ups i.e. 50% weight, 65% weight then your max for 6 reps or whatever rep range you choose.
3. Don't pick up the bar with your palm but instead pick it up closer to where your fingers meet your palm.
just spent 2 weeks in byron bay and although I tried to get walks and swims in every day I'm feeling like I need a heavy gym session badly... only upside is I've actually got a decent tan for once :banana:
still can't totally get rid of gut flab... was doing the fasted cardio morning walk thing but kinda offset it by drinking all afternoon lol... really annoying, need to get rid of that last bit round my lower abs and lower back... every time I almost get there I ruin it by eating and drinking like a fat bastard... but when your on holiday you gotta do what feels good hehe
some seriously ripped surfers up there... hitting the surf everyday is a great workout, paddling a board great for your shoulders/back... dudes are built but lean as... made me all jelly
in the plus column I did get one 'holy shit your back is huge' from a mate who hadn't seen me with the shirt off in a while... nohomo of course :thumbsup:
sigh... back to the grind
Birds - you've mentioned many times that you are not after outright strength, so I don't see why you wouldn't use straps.
sets of 10 on deadlifts are farking hard.
since you've already ruled out all the best options ie, alternate grip, no gloves but with chalk, straps are the only answer if your insisting on sets of 10.
Quick question.
do you do Bent over BB rows or chins?
if so, what set x reps and what weight?
Serious question...
Ok, i'll go through some options for you.
-Doing deadlifts first will mean your grip will be a bit stronger, however it's not going to strengthen your grip as you'd know.
-Using alternate grip will mean you can lift more, alot more, but will again not really strengthen your grip directly, however the extra weight lifted will have some transfer to your grip.
-If you want to lift with a pronated grip, then i'd suggest start using the hook grip as above. Painfull for a while, but well worth it.
-Gloves will lower your grip somewhat as opposed to chalk, but if you want to wear them so be it.
A long time ago i had the same issue, where my grip used to fail before my back/legs. For myself, i used and still do use captain of crush grippers to keep my crushing grip in check, and for static grip i did alot of farmers walks. These two will transfer over to your deadlift tremendously.
Just remember, doing an overhand grip without using hook grip means your grip will fail alot sooner. Even with a hook grip it takes alot of practice and training. Overhand i reckon i could do maybe 140-150 for a few, but alternate I'll have no problem at all doing 140 for 20reps, with grip still not being an issue.
But in answer to your question, buy some coc grippers and do heavy farmers walks a few times a week.
This. If I ever remember farmer's walks, I usually do 20kg in each hand for about 100m give or take. By the end my delts (f**k knows why) and my forearms are on fire.
That's not a farmer's walk! My girlfriend does that after a day at Chadstone. Farmer's walk should be so heavy it threatens to (and does) rip your callouses off.
Bahahaha
He's got u there mate
8 sessions in, fkn loving it. Working hard and growing again; past 3 sessions been working out for 90mins. Dropped midrift fat and gaining muscle quickly.
Started supp intake this week, jack3d pre shake, post shake of fish oil + 50g whey protein + 60g dextrose monohydrate + 10g creatine + 10g BCAA powder
Query - not real sure what I can do with my legs seeing Im 2m tall but have no kneecaps.
Squats, leg extensions, lunges, etc are out. Cant kneel nor squat.
I start off with standing calf raises, laying hamstring curls, standing hamstring curls to finish them off, seated horizontal leg press (must be careful considering patella tendon takes the load), and today added in a seated leg curl (legs horizontal pulling down to seated position). All up thats around half hour..... anything else I could consider adding in? Using cable 'Panetta' machines besides the calf raises.
Then move onto upper body work for 40mins, gut crunches and 5km bike work to finish off.
+1
With slipping grips with deadlifting;
Hold the bar with one hand facing away from you, and one facing towards you, and alternate hands with sets.
100KG isn't that heavy... just close your eyes, focus on keeping form and holding on... you should be fine after a couple weeks.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
