A little bit out from my first guess :blush: but inline with Birds estimate!!!
Hey would ya look at that :D
Think about it though, it you can drop ~7/8kg and end up with 10% bf (assuming some small muscle loss at the same time), you'll look super lean and retain ~95% of your strength for a good power to weight ratio. Not such a bad statistic to keep track of :)
Let's not forget the table that GTSBOY( I think) posted a few weeks ago, just because a supplements states it has a certain amount of protein doesnt mean squat.. Your lucky if your getting 90% of what it says it has.. I'm switching over to optimum nutrition, 1 cause it actually has most of what it says it does and 2 if tastes awesome
Btw, just like setting a track/drag car up properly, it's all the 1%ers that make the difference in the end..
Lets not forget not even 5% of the products on the market were tested :)
They didn't test BN, so you can't say it's bad/misleading. I know a lot of guys that compete, that tell me BN = way to go (from a price point)... Trust 140kg builders over a dude with a spreadsheet :)
Never said anything about BN.. Just pointing out that there is alot of rubbish out there on the market..
Changed my mind again, I'll be swapping to ISOFLEX.. A Good mate of mine recommended it.. No he's not 140kg.. He's just 137 :)
I'm taking ON protein. Called Hydrobuilder - chocolate flavour. Bit on the expensive side but I've always taken ON products.
As I've mentioned in an earlier post, strong stimulants give you the bad "coming off" effect. Long term useage means your body adapts to it then you need to increase the dosage but at the same time you start to depend on it to the point where you hit a threshold. When I use my Pre, it doesn't have any DMAA so you don't feel jacked up then just crash. Nevetheless, still require on and off periods.
Also the whole post workout insulin spike thing is true and does have good benefits but for your average joe blow then it doesn't matter. You still can yield some decent results. Someone like me who is type 1 Diab, can use any amout of insulin for it's anabolic effect providing that I ingest enough fast acting carbs when your body is most depleted. Insulin helps feed your muscle being a very powerful hormone but at the same time can make you fat.
I wish I never took a pre-workout supp, become too dependant on them now, Anyway I made some protein bars for the first time last night, they seemed set this morning but I'll check them out when I get home - better be good lol.
if you snatched 100kg like that I'd be fckn impressed... I can barely power clean and push press my own bodyweight... and its not pretty lol
I was reading an article that was talking about strength goals for athletes (not powerlifters, weightlifters or strong men etc) so have been trying for these goals
Push
Body weight bench press for 15 reps - tried over the weekend, only got 12 and last rep was a bit suspect :(
Pull
15 pull-ups - easy, can do 20
Squat
Body weight squat for 15 reps - hard work, can do 20 though
Hinge
Double body weight deadlift - did 180kg at 82kg bodyweight
Loaded Carry (Farmer Walk) 40 metres
Body weight per hand - haven't tried this one, will have to find a space but it sounds bloody difficult... would have to work up to it I imagine
Yer but I do have a pretty low BF. I also think I have a good power/weight ratio if you take into account my height. What do you weigh at the moment, Nick? Farmer walk sounds tough...I think my grip would let go on that one before the legs give out. Just carrying the 32.5's back to the racks after a set of incline dumbells is taxing on it's own.
Have stepped up behind neck mlitary press to 50kg x 10 on the 4th/5th/6th sets - another exercise that I neglected to move up in weight (45kg x 10 for the last 4-5 years). Going to shoot for 55kg x 10 soon and the end goal is to work my way up to a full set of 10 x bodyweight. Another 30kg to go, gonna be tough lol.
Sort of related: what is it called when you pick the barbell up off the ground and in one single motion sweep it up to above your head? This is the way I pick up a barbell when I am starting a military press set. I thought it was some variation of the clean/snatch, but on googling these, they all involve a squat movement at some point...I'm literally deadlifting it from the ground to above my head in one.
82-83kg... but carrying a few kilos of fat I could probably do without...l probably somewhere between 15-20%
it doesn't really have a name, I think you just invented it lol... you can do a hang snatch which is kinda what your doing... that's where you start with the bar just below your knees, bent at the waist like your half way through a DL and then you straighten and throw the bar above your head in one motion
next time you pick the bar up off the ground try and clean or snatch it... obviously start with a very light weight until you get the motion down... then you can work in two exercises into the one set... snatch the bar to above your head, lower then press it, lower it back to just below your knees, snatch it above our head again etc
We will call it the Birds clean! Looked up hang snatch and that sounds kind of similar. I actually described what I do inaccurately, before...there are actually two movements to what I do in preparation for military press. I deadlift the barbell off the ground, take a couple steps back...dip the barbell and bend knees a bit in a bit of a spring motion, then upright row / thrust it with my whole body to the top of a military press movement. Might have to video this one lol.
Sounds like a good full body exercise but I do squats on the same day and my military press is done very strictly...don't really want to incorporate other motions into it.
lol @ vid, thought meh 70kg, will be there soon enough...then the 100kg put me in my place lol.
yeah I did the same thing, then he cruised the 100kg up without any struggle... bit of a beast really!
when its cold and I don't feel like training I start with a barbell complex... rule is your not allowed to rest or put the weight down between exercises... usually something like RDL, into bent over rows, into power cleans, into overhead press, into back or front squat... pick a weight that you can do the hardest exercise with (usually OHP) and do 6 or 7 of each... 30-40kg will make you hate life... good for us guys who need to burn off a few more calories;) probably not necessary for you lean bastards lol
Yeah that sounds like a full body workout / HIIT all in one lol.
Speaking of lean bastards, it's been a while since I've gayed up the thread with a selfie...56k and homo warning!
I've been cutting up a bit lately and this is where I'm at. Trying to get in shape for fitness model comps, for which another 2-3% less fat should do the trick. Oddly enough, I weigh much the same as before the cut (it hasnt been an aggressive cut), leading me to believe that leg muscle gains are countering the fat loss (I hope so anyway).
How'm I doin fellas?
Shave your chest bruv! You have good abdominal genetics it seems, pretty much perfectly lined up splits in the muscle. Bit of a shitty angle for a pic though tbh, you should upload the standard mirror shot standing up to show proper fat % (orlackof).
Inb4 nohomo quotes
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
    • Staring on a stand is no issue. You just have to wire everything up, give it fuel and cross your fingers that the stand is robust enough. Arranging the inlet plumbing is often the hardest part, without any surrounding structure to hand some of it from. No need for coolant if you only want to run it for <1 minute. As to the gearbox - I think the little Aisin box is a bit stronger than the other small Nissan boxes that went behind SRs, but I wouldn't be too keen to test its limits with the torque of a boosted 25. I don't know if you can retain the box and the tailshaft. The box won't connect to the RB without an adapter of some sort, which is either a plate that will push the engine forward (which is not good for fitting it into the bay's available space) or push the box back, which messes with the box position and tailshaft length - OR - cut and shut work on the bellhousing, which is a long way from "least modification". I'd be buying a new 370Z 6 speed or similar, doing what has to be done to that to make it fit RB (ie, cut and shut bellhousing) and the requisite tailshaft custom/mods.
