They are primarily nothing...what they work depends on how you do them, as there are many different styles of deadlifts. Off the ground in a full squat position is going to have more leg involvement, where as stiff legged with minimal leg bend will target your lower back throughout the range of motion.
Just see what muscles give you DOMS I guess, then you'll know what your deadlifts are "primarily" working lol.
What do you think the lumbar erectors are?
Erector spinae is the blanket term for the muscles that run parrallel to the spine.
There is iliocostalis lumborum, spinalis dorsi and longissimus dorsi all in the lumbar region. Deadlifts will also hit quadratic lumborum, but it's not grouped in with the "erector spinae" term.
It's just habit for me to refer to them as lumbar erectors to be slightly specific without naming them I guess...
Edited by Mitcho_7
brids was right, depending on how you do deads will depend greatly on what muscles are used the most and at what point.
i find normal deadlifts (where you actually hit the ground and reset every rep) to do the entire body, however if i lower the bar to near the ground without actually touching, it hits my back a thousand times more, I also find that I can do more reps this way.
sumo deads will do your arse and back more, stiff I find hits my hammys etc etc
Trying to decide if I should be getting something now to bulk up a little or just stick with it and increase my eating.
I have lost a total of 8kg over the past few months now since starting.
Currently sitting at 69kg 170cm
When you make up your mind let me know, I might be keen on getting some more stuff.
News just in guys.....
The gym and supplement Discussion world came to a screaching hault today when a 69kg man questioned wether he should start bulking up a little.
One witness was quoted as saying "dafuq?"
After some investigation it was found that the 69kg man [man...lol.. yeah right - Editor] was in fact studying to become a Bosu Ball instructor and so the shocking news was not so shocking but still quite queer.
Edited by TTT
I would just increase your eating like you said. You can make a DIY weight gainer (grinded oats, PB, milk and whey) which is pretty convenient. tastes alright as well.
Edited by Dani Boi
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
