Nuts are the worst thing to suck on. I just can't f**king stop sucking them once I start!!
Come on man, this is a PG forum.
Squats help with addiction.
Squats cure gheys
I wouldn't so much say they cure them, but they certainly make it clear who they are - they're the ones shitting themselves on the way back up from worn out sphincters.
yeah i didnt like it either, but had to be done. The alternative was to leave without squating or wait 20 minutes for it.
funny thing, because my current routine jumps around the body for push pull, earlier in the routine I did standing military with the Olympic bar. Don't know why but it felt so much better then using just a normal barbell.
Why don't you make Barbell exercises primary?
20mins isn't so bad to wait if it's before you've started especially if you include warm up/stretches
No squats is > than doing it in a smith machine. You'll injure yourself....
Love smashing these legs. No squats makes me cry inside tho :(
Trying Maxs mass gainer cookies & cream, omg so nice!!
My mix I made up is horrid, but with a cple of scoops of max irs like a party in my mouth, without nuts!!
Bloated gut the morning after binging....had a heap of home made banana cake last night at parent's place, followed by like a third of a jar of organic peanut butter on rye biscuits.
Not even unhealthy!! hahahaha I've mentally conditioned myself a bit too far I think lol
Oh also on the subject of smith machine squats vs nothing - if the power cages are all taken, consider doing some goblet squats while you wait.
I'm sure you probably know what they are, but in case you don't they're where you hold a dumbbell vertically under your chin against your chest and squat with it there. I will generally use a 40kg dumbbell, so obviously you can tell this isn't particularly a leg exercise; but my god does it work your core.
At least this will kill some time while you wait to do real squats.
or why not hold dumbells (2 x 25kg etc) above shoulders like doing a shoulder press and then squat like that? or even, using the fixed barbells for squats without a cage, cos they usually aren't so heavy that you need a cage anyway and still are solid squats. just not the weight...but can focus on reps
Dumbell squats! Hold them like suitcases...don't need a cage cause you can just lower them to the floor. My gym has 65kg dumbells, so not as if you're getting off easy.
Shit even leg press isn't a bad alternative.
barbell front squats... you will find even light weight quite difficult and you won't need the cage... pick it up as you would a deadlift... hang clean it to your shoulders... front squat
great for your quads
Definently agree with this. Front squats are the business!
Hey mate... this is how eating disorders start..
I'm not joking.
I'm not joking.
Exactly what do you mean by disorder? As in, skinny or fat direction?
I agree though, I can't necessarily 'enjoy' food any more. If you mean eating disorder that sees me unable to eat 99% of available foods because I see them as "unhealthy" and "fattening" then I agree and see why you mean.
I'll have a hugely relaxed mindset over the Christmas period, then again as soon as Summer is over I'm going to relax it again (since shirt will be staying on a lot more lol) and start aiming for some real gains. Depending on a lot of variables like injury etc, I'm going to aim for 225kg deadlift by end of winter next year, which I hope to be able to maintain while I cut back to somewhere around 75kg for summer - ideally achieving triple bodyweight deadlift.
I'm undoubtedly setting slightly unrealistic goals here, but yeah...
Troy - I meant heading towards skinny.
A mate from another forum was 85kg and lean.. but wanted to get to single digits, so cut some more..
got to single digits but still wanted to get even tighter around the lower abs and obliques (he already was but at this stage he was well on his way to his problem.)
got down to 78kg and was lean as.
then, just like you say, he wanted to hold on to it, so stayed away from certain foods, just basically went to the extreme with food, training, sleep, timing of when he eats and what, timing around lifting, rest, duration or sets etc etc.
Anyway, he dissapeared off the forums for about 4 months and made a return.
When he came back online, he eventualy posted a thread titled "Guys, I've got a problem"
he told his story as above and then said that he'd been sick and then said he was 43kg and posted a picture.
I shit you not, it was a scary sight.
a skeleton of a man.
a long 18 months later he was back to a light 70kg.
he had to see a psychologist 3 times a week, a nutritionist 2 times a week and his doctor once a week.
for months they tried to get his blood work to how it should be for his age, but his body was f**ked up and wouldn't produce hormones like youd expect a mid 20's guy who used to lift.
Eventually had to be put on TRT.
It took him AGES to get his mind right and stop seeing himself as fat (even when he was around 50kg)
He is now 95kg, has benched close to 150, squats 200 and deadlifts 240
and is still fairly lean.
long story but I'm sure you can see some similarities from the story to what goes through your head.
Be careful mate.
Mitch - Do I need to remind you how to fix that?
    • @PranK to help you feel better, this is what happens when you run two of the big ones and have a heavy foot...
    • Nice, saves me ranting about how painful it is painting a roof with rattle cans lol.  Personally, I wouldn't chase the rust back any further. What happens if your 30cm deep into your roof and still going? This is why I was suggesting fiberglass, the holes are quite large but easy to patch with fibreglass. There will be a million youtube videos of people doing this shonky job you can check out for a visual.  Once the holes are patched with fibreglass, you can rebuild the corner with body filler (like the last guy did).  Indeed, its a shit go
    • Filler will set solid and water tight. If you need to, get in around the inside with silicon between the window and edge of the car, but only if that spot is leaking.
    • I have a decent compressor and spray gun. I haven't done anything this big but between it and the bonnet the paint currently is absolutely terrible and there's no chance I'd make it worse.  Ok so should I cut back the top flap to get to the end of the rust? The bottom bit looks bad but feels strong still, even with the holes.  Will filler seal the holes? Or should I put some silicon in them first?  Love your work guys, thanks. Can't tell you how bummed I am to have found this. Wish I'd never looked and I'd still be happy!
    • Yeah this can't be overstated, this job is crazy hard even for a professional.
