All I hear is whinging about techniques and width of equipment. At least you can move both your arms and do the friggen exercise. If I could do dips between two shopping trolleys with a couple of retards holding them in place I would.
angry_birds___red___super_high_quality__
yes and yes
an olympic bar is 7', 20kg, bearing collars and takes olympic plates (the big hole ones)
standard bar is the stuff you have.
they also make an olympic ladies bar which is 6' and 15kg. the collars are shorter and the gap between the collars is the same as the 7' ones.
just incase you want the lady version.
Sell your shit on ebay, add some more money to your funds and get a cage/bar and plates package like this..
http://www.cyber-market.com.au/cyberfit-power-rack-100kg-olympic-weight-flat-bench-p-591.html
More than you'll need for a while.. and you can always buy more plates as needed.
or if you want to retain your plates you could get something like this..
http://www.gymdirect.com.au/item/5-Package-Deal-_-BPR02-Power-Rack-with-high-low-pulley--+-FD3-flat-bench-+-100kg-barbell-dumbell-set-$865/109.htm
Just trying to follow your logic on buying an entire kit if there's an option to just buy a longer standard bar. Doesn't seem like there is any unless the goal is to ultimately move to Olympic gear.
So I have a new attitude towards this shoulder injury. I thought f**k it...I'm gonna come out the other side of this thing with a positive: huge f**k off legs. Time to make up for the years of neglecting legs in favour of upper body.
So until the physio gives me the all clear on upper body movements, I'm gonna smash the shit out of legs 3-4 times a week. This will involve:
Squats
Squats
Leg press
Hamstring curls
Calf raises
Possibly more squats
Legs progress shot from me.
Congratulations dude, you're my motivation to put some serious size on my legs over the next 8 weeks or so.
Exactly!!!
I can't do chest so have trained legs twice this week. Tonight was shoulders and traps but before that did 10mins on the bike as warm up and then 5 sets of squats.
Want my legs to get heaps bigger and stronger in the next month.
Fark that session felt good. Hamstring curl smashed my hamstrings in a way that deadlifts can't. And it'll be good to balance out legs with some calf work for aesthetics :)
Satisfaction at the end almost makes up for no upper body work during the session. More energy for squats too, which I normally save for the end of the session.
Sounds good Birds. Hope it all goes well for you mate. An old PT mate of mine stuffed a tendon in his wrist (forget the exact injury but basically sheared off the bone I believe) but it was depressing the number of exercises that ruled out. He found ways to use wraps or particular machines to work around it as much as possible until it healed up completely
With legs being such a big muscle group too I think it should help burn the calories up
I've always had decent upper legs, they would be my best body part. Have never had to do too much to them to maintain volume and they respond well for me. Whereas back , shoulders etc I seem to need to work continually to maintain any size. I'm going to focus on the calves a lot more and hope for some sort of development there. apparently for some people it doesn't seem to matter what you do they just wont respond.
Advice/help from those in the know please.
I have a fairly noticeable size difference between legs due to an old knee injury and would like some guidance as to how to even them up. I have full range of movement but the injured knee isn't as stable as my good knee.
My lower body workout currently consist of the following once a week: Walking lunges, Squats (parallel), Deadlifts, Hamstring curls, calf raises, single leg dead lifts and jumping squats.
Try to do cardio twice a week, HIIT resistance circuit, HIIT on rowing machine/stationary cycle, if I have time XC mountain biking. Also do two upper body days a week, a three day split works best for me so I can keep workouts short after a long day at work. No training Sunday/Monday.
Some people tell me to do single leg exercises and do more reps for the weak leg, others say start with weak leg and only do the same amount of reps for both sides. Other people insist I should keep doing what I’m already doing and just concentrate on driving with the weaker leg more.
I train for general health and to blow off steam after a 13+ hr shifts.
I do need to have a reco at some point but time, money and rehab process put me off the idea while it mostly works ok.
If anyone can help me out that would be great as it's really starting to shit me.
EDIT: I just worked it out MORE SQUATS!
Edited by numleg
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
    • A few random issues have popped up since my last update. My WMI pressure sensor failed within about 10 minutes of it seeing liquid. It was a 20$ China special, so I'm not surprised. My name brand replacement should arrive today.  My power steering assist also decided to crap out last weekend. The usual, works for about 60 seconds after starting the car then I lose it. I dusted off my old copy of NDS and connected to the HICAS ECU. Code 4 for assist solenoid.... I tested the solenoid and it's fine.  I knew the day where my HICAS ecu would crap out would come, and I welcome it. It was the last HICAS part on the car that is now in the bin. I've ordered an SSR and I will control the power steering solenoid with my Haltech ecu. It will be nice to have proper speed referenced assist again after all these years.
    • Haha I just finished the last season of TPB: Jail last month. I'm happy they're still pumping out episodes.
