Yeah gonna suffer DOMS hard, but should be worth it. If I find the load too taxing I'll cut down. I just wanna exercise as much as I can to make up for lack of upper body movements. Need to keep the calories off.
I don't think you need to worry about this, especially next week.
If you injured yourself badly I'd be reluctant to lean on it without at least giving it a weeks rest.
Better yet, see your chosen therapist and see what they say.
Seems like you're busy enough squatting anyway :)
Tried an empty bench bar in the same session and it didn't present any pain...I could be back to upper body sooner than I thought :)
Playing it safe though. Do we think it's worth doing movements like bench with an empty bar for rehab? Or just wait until completely healed and get back into the weights?
Feeling pain or not, isn't a good indicator with the rotator for recovery. The pain is there when the swelling goes up and that can take a few minutes to an hour before you start hurting. Hence your bench blew it out but, you didn't feel it till later on a relatively light excersise. You can have deterioration in the muscle without feeling it as pain, so be carefull.
testing very carefully the 'weakness' is the way to go. You want the strength to be at least that of the unijured side.
Bench press isn't a rehab movement for this injury. Don't bother with it. Even the empty bar bench doesn't address anything related and you just look like a feeb doing it.
Copy/paste from my build thread as questions get answered quicker in here.
For some reason, my back is worse than it's been so I either did something Friday night or sleeping in shit hospital chairs/not sleeping is giving me grief (Kate has been in pre-labour for the last 3 days so we've been in and out and not sleeping very much). No gym on Monday as a result so I've had a good 3-4 days off.
Not even a stretch is helping me and it's pinching randomly when I'm not doing much.
I've noticed, with squats, that if I go below parallel my body tends to lean forward at the bottom of the motion which I'm wondering if that's causing some kind of cantilever effect on my lower back as I come back up. Or is some form of forward tilt at the bottom of the motion normal/acceptable?
Extra info: A podiatrist friend came over on sunday and did some tests, said my legs are 1.5cm different lengths, specifically from the waist down so nothing from the back as she measured that too. I put orthotics back in my shoes (just off the shelf ones) on her advice on Sunday but I "think" my back was already playing up before that.
Edited by ActionDan
    • Hi all,  I am in the market for an R200 longnose diff out of a Z31 300ZX, or S12 RSX, DR30 skyline, or similar, in a 3.9 ratio.  Preferably a late model one with the M12 crownwheel bolts.  The only easy to find advert for one of these was my ad back in 2007 when I sold it on this forum.  I sold the diff as I had sold the car it goes to, but as it turns out, after 18 years I got the car back late last year, so now I'm looking for the diff !  If anyone knows where to find a longnose R200 LSD with the M12 crownwheel bolts, drop me a line at [email protected] - Bonus paid if soomeone comes up with the original diff (stranger things have happened !).  Cheers   Ben D
    • Hi everyone, I used to post here a bit from 2004-2013, when I owned various Nissans, in particular my S12 RSX gazelle, which was sold in 2007.  As luck would have it, after an 18 year hiatus, the car found its way back to me last year, and over the past 11 months I have had the pleasure of restoring it with my kids.  One thing that I am after in particular is a 3.9 ratio R200 LSD for it.  I actually sold the one out of the car here back in 2007 , and it would be incredible if I could track down who I sold it to, so I can see how they have progressed over the years (and to be honest, to see whether I can get the diff back !).  Anyways, hi all and let me know "where are the R200 Longnose diffs all at these days ?  Cheers Ben D
    • Arms will be the same as the G35 or 350Z, but as above, there was a change in the lower control arm where it connects to the ball joint.  That said, you can remove the ball joint cone from your old ball joints and fit them to the new ball joints.  To be honest, I didn't think the ball joints themselves were different. The main ball joint is a bit awkward to replace, you really need to remove the steering knuckle to press out the old one.  Some people have used tools to remove it in place, but it just seemed too hard to get to. If you are going to press out/in that ball joint, then you may as well just replace the bushings in the LCA and the compression rod.  You can buy the compression rod bushing from Nissan, but the LCA bushes, you will need to go aftermarket. Much cheaper than buying the whole arm.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
