Does that stuff strike you as being cheap crap?
Is there anything you can see obviously wrong with gear for light home use or are you generalising?
Can you show me what you consider decent so I've got a comparison?
Edited by ActionDan
The benches appear cheap to tell you the truth. They look like they wouldn't be very stable/solid, and the material of the upper (pads) wouldn't be very durable.
The cage looks alright, but the materials themselves look a little thin? I could be wrong though. Its hard to tell unless you see it in person..
Just generalising tbh. Going by the typical "if it looks too good to be true, that's because it is" principal.
There's nothing wrong with cheaper equipment for home use, but I doubt the warranties would be worth the paper they're written on, so it's better to spend a bit more for a setup that will last a lifetime.
I'm not saying the stuff I sell is the greatest, but at least it's tested and rated, and the warranties are usually quite good.
e.g.
http://www.gymquipfitness.com/product-details.php?action=view&proId=555
http://www.gymquipfitness.com/product-details.php?action=view&proId=149
The lat pulldowns, etc on power racks are usually quite gimmicky as they aren't strong enough to take a decent amount of weight.
Thanks TTT.
God_speed: Correct, they can be moved inside the rack and yes I've never done incline bench. I've never been madly into weights or overly strong, I just do it to keep some level of physique (I work an office job) and to assist with working on my car/around the house. I've never repped more than 100kg on the bench anyway (atm only a touch over 90kg) and it's only been recently that I've started making an effort to do some more compound work and get involved in some of the "proper" lifts like squats and DLs etc, hence the rack.
No worries Dan. I'm in a similar situation. Definitely recommend incorporating incline in your setup / routine. Decline as well if possible.
Agree on seeing the equipment before buying. Have bought a cheap bench setup way back and the welds holding the seat (split seat/backrest) to the frame snapped. POS. If you can I would shell out more to get a decent build, it will last longer, feel better to use (sturdier, fewer problems like cable sheathing crapping out, frames bending etc) and you should get some form of resale out of it as well
Wow, no doubt it's a good bench but for that money I could buy 7 average ones =\
I realise safety is also a factor.
http://www.gymquipfitness.com/product-details.php?action=view&proId=134
^top level domestic bench (adjustable)
They're way better to use than pin-locking benches too, all you do is lift the pad and it locks on one of the teeth along the support.
EDIT: Anyway, enough advertising in this thread.
Edited by TM7GTR
Why do you believe incline and decline bench should be done?
TTT I did flat bench for yonks with only occasional incline work. Had decent depth in the pecs but lacking a lot near the clavicle / pec major... I found doing a lot of volume on incline work over the past 2-3 years helped bring that out, a lot. With decline, I don't notice the effects as readily, but I find it is good for balancing out the incline work as well as finishing off the chest routine as I find them easier to do.
Haha! The only true stability test any bench needs
Or what about these two? look mid range?
http://www.fitonline.com.au/p/4304600/york-aspire-fid-dumbell-bench.html
http://www.fitonline.com.au/p/4281877/bodyworx-c324sb-fid-utility-bench.html
Odd that they top out at 200kg.
I'm 86kg now, repping 91ish kg, that's already 75% of the capacity and Im not a big lifter.
then again, realistically I won't go much if anything beyond 90kg in weight and maybe 100kg rep on the bench, not much room after that though and I suppose that's a ways off.
Definitely prefer the York one for what you want it for, you'd definitely find those leg extension pads getting in the way.
Dunno why they're only rated at 200 but the fact it says 'user weight' makes me think they have factored in the use of some weights on top of the user weight... what weight exactly, who knows? But 200 is stuff all. And Dan I wouldn't put it past yourself to bench more than 100 in the near future, if you're 86kg youre pretty much the same weight as me and I can bench that but don't consider it to be at all a strong bench figure.
I know I "could" bench more as I used to rep in the 110 range for sets of 10 but I have no desire to go back to that in terms of chest size. I'd be happy to get back to an even 100 for the psychological factor.
What do you think Tom, the York one look better?
I should see if I can even bench 100kg lol. Most I've ever even bothered unracking was 95kg, which I managed 3 (sketchy) reps from memory. Been sticking to dumbbells lately, predominantly incline press over flat (aesthetic basis). Pushed out 36kg x7,7,6,7 reps last night, which is a PB on incline for me. New PB for flat DB press too last week - 42kg x7 on my 4th set.
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
