rev: when I say being strict on myself, I mean not giving in to the desire to eat whatever, or getting on the booze whenever without thinking all the time. It doesn't mean that I'm putting myself on a punishment diet.
I still have my 'cheat' meals (or even days at times, it can be unavoidable). Depends on what your goals are, some want to just lift heavy, some want to look swole, some want aesthetics (<10% bf) etc.
I'm personally trying to lose fat without losing muscle (well as little as possible). I also think that if you're not motivated from within like I am, then it's a LOT harder to stick with it. I've got a lot of people to prove wrong as well.
Birds, do you always try this hard to be edgy?
Edited by bozodos
I didn't want to flood the DL thread with my questions so I'll dump it here.
As a an absolute virgin to deadlifting before about, 2mths ago, I've really struggled with the idea/form etc.
I started at 30kg (same for squats) on an ezy bar as I only had a standard 6ft bar and I was too lazy to take the weights off it from bench, now I have a rack and a 7ft bar.
I've been making only very small increases as my back has been a bit iffy along the way due to pelvis alignment and stability issues from breaking my leg/dislocating my ankle. So I've been working on that with a physio, jogging daily and made squatting and deadlifting a part of my routine to get my legs and back solid - my old routine used to be pretty much all upper body work as you guys will remember.
I now deadlift a stunning 60kg for 3x8 (squat is currently 66) I feel like I could add some weigh to the squat without too much drama but the dead feels like slower progress and much harder work. After 3 sets I have a good puff, nothing else taxes me the same way so I'm guessing it's a combo of doing it wrong, poor strength in required areas from having only just started to get into it, and being over cautious with my lower back which has proven that if I don't treat it properly it will jam up on me like last week.
If I had a question, it would be why am I so shit at squat/dl when I see people much lighter squat and DL literally 3 times the amounts. Is it simply that because I've only just started out I don't have a great foundation? Am I just inherently weak in that area? to be fair, I'm not overly strong in any direction and my bench is probably only half OK because I favoured it for so long (repping 96kg at the moment, will up that to 100kg shortly and just leave it there, no idea what 1RMs are, not interested).
Pretty sure Leesh out squats and out deads me, good for her, not so much for my pride :D
I should clarify, I feel I can definitely add squat weight but I do so very slowly to allow my back and ankle to keep pace.
DL's yeah I probably 'could' add weight but form would suffer.
If I had to think about it, I probably feel "weakest" in my back, my quads get busy during the motion and I feel a good burn in there, but it's my back that I'm focusing on the most.
Probably doesn't help that I sit all day and have done for my working life so far.
The advice is sound though and I'll have a chat with another mate of mine on the weekend who's shorter, lighter, and a shed load stronger (training bodybuilder so looks matter more than numbers but still).
Markos doesn't check this thread due to the amount of Birds-ism in here.
Go visit Laurie Butler.. look him up if you want to know who he is..
http://www.supershape.com.au/index.html
http://www.supershape.com.au/contact.html
Forget about the offerings..
go pay one session and ask Laurie many questions and ask to be shown how to do stuff properly.
No doubt.
Just making sure I had the names right so I didn't say something inappropriate like oh is this that gym were those druggos got done...
At $70 for a one hour session, it pays for itself if it stops me doing an injury and having to go back to paid osteo etc, I'll look into it.
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
