lol no dude, I'm just a realist, ergo, there is no ego :)
I also joke around a fair bit...
I think you're more of a pessimist :P
As for realism...no one ever did anything amazing by accepting mediocrity!
The day is getting closer where I hold an exclusive SAU strength comp, not a PL meet
Bodyweight reps type stuff etc
I would be down for this...perhaps some old school PTC feats of strength, pushing cars etc.
But given the success rate of competitions on here, I remain skeptical about attendance :(
We'll have to agree to disagree then :)
I'm not out for amazing, but don't let that stop you Tony Robbins lol
Oh cool, glad we got that sorted. Does this mean you'll stop mentioning how others, including girls, are stronger than you :P
Thoughts on compression socks? As in the almost knew high style?
The Physio recommended I look at one for the bad leg during gym and morning jogs to help stop that ankle rolling in as it seems to want to.
She suggested 2XU but there appears to a few options. She said 2XU specifically because they have circumferential compression where as the Skins brand are vertical according to her.
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
