Here are some ideas ;
* Sucking in your gut to activate the abbs (wrong). Instead stabilise the abs. pull air in (breathe in) and push the gut out
* not using glutes enough
* You are trying to squat too low with the low bar. If you don't have the extra hip flexibillity your back will round.
It will be your hip movement. Squats done right don't bugger up your lower back. Bad form is going to tell you in the lower back.
Also consider hamstrings could be too tight, in turn causing minor pelvic rotation > tight lower back muscles as they try to compensate/counter the pull from your hamstrings. This is almost certainly MY problem with lower back muscle pain.
Possibly, but I'd like to think I'm one of the more active stretchers/foam rollers here but that doesn't necessarily mean I'm being effective with the time spent or that there's not some other underlying issue that stretching doesn't fix.
I've found in the past that I usually have to "reset" which is normally take a week or two off aggravating motions, then begin specific work for the problem areas, it took me a good few years to get my elbow right after it was hammered from all the bro curls but now it's as good as it's ever been, it just takes time (hopefully not that long though as I've learned a lot about how to recovery from these sorts of things).
I'll get there.
Ugh making me open SAU on my farken laptop mate....goddamn.
Also unless it's Epic Meal Time or similar, I could guarantee you I'd be putting up a fight (comparing caloric intake in a sitting - not necessarily volume of food). I've made myself sick a couple of times when I did my silly bulk few months back lol
It's 10 mins long....could you give me a TL;DW rundown? haha 12,000+ calories in what timeframe? The whole day, or one sitting? Going by the thumbnail for the video, looks like there's ridiculous amount of cheese (fat) involved :D and dickloads of pasta/dough/bread.
I could do 12,000cal over a couple of hours with a few loaves of bread, couple of jars of peanut butter, and honey.....who needs protein PFFT!
4 cups of oatmeal with blueberries
1 kg of pasta
1 family / 1" pizza
2 large cheese and ham sandwiches
3 chocolate chip pancakes
3 French toasts
5 egg omelette
3 egg and cheese toasted sandwiches
5 rockstar energy drinks
42 minutes
Shiiiiiit.....hmm, I reckon if I prepared for it (and got really high) I could make quite the dent in that....but definitely not all of it in that timeframe. No f**king way.
And I wouldn't f**king touch those energy drinks. I'd sooner just eat tablespoons of sugar. At least then I wouldn't want to vomit (well, I would....but energy drinks are f**king rancid)
He's a professional eater; number 5 in the world, so I don't expect you to come close to anything he does lol
He did 120 Maccas chicken nuggets in 14 minutes...I get sick after 25.
Rockstar isn't bad, used to drink it in my LAN place days along with onion rings and milo bars.
There's a vid of a guy drinking 24k calories of olive oil. Definitely hit fat macro for the next month
The aftermath of that endeavour would've been unpleasant lol...I believe he mentioned in the video description that he'd been pissing oil out his ass for a few hours hahaha
Calories are easily piled of just eating high fatty shit. The days when I use to maul down a 1kg bag of honey roasted cashews a few times a week and spend most of the time in the toilet due to the extreme fibre punch. Not to mention it...I was a fat f**k
Edited by vspecIInur
    • LOL.... a good amount of people (not all) on that continent seem to know everything and like to measure things in bananas, football fields, statue of liberties instead of the metric system lol.
    • I assume the modules are similar enough, so if you've had no issues I don't see why I would. I have tried to find a wiring diagram for the FPCM / fuel pump circuit, but I can't find it anywhere. Otherwise, I would just do some wire cutting and joining at the FPCM and give the 12 V supplied to the FPCM directly to the pump instead. If you know anyone that could help with wiring diagrams, I'd be very happy
    • If it dies, then bypass. The task isn't difficult. I have one running on a standard R32 FPCM. That's after nearly 20 years of it running an 040, which pull substantially more current than the Walbro. They're not the same module, but I'd hope it indicates that the R33 one should be man enough for the job. I think people kill them when putting proper sized pumps on them, not these little toy pumps we're talking about here.
    • Silicone spray won't hurt anything. And if it does, that's an opportunity to put some solid steel spherical bushings in, so you can really learn what suspension noise sounds like, If you're going to try it, just spray one bush at a time, so you can work out which one is actually noisy. My best guess is that if the noise started only since putting the coilovers in, then it is just noise being transmitted up through the top mounts of the struts, and not necessarily "new" noise from bushes. But it's almost impossible to know.
    • Are you saying the 34 is SUV height, and not that we're talking about an SUV here? (because if we're talking about an SUV, you don't fix them. You just replace them when something breaks. Not worth establishing sufficient emotional connection with an SUV to warrant doing any work on one). I wouldn't jack my car up on a short little loop of 10mm steel rod poking out through a hole in the bumper bar, front or rear end. I realise that we're probably not talking about that type of loop at the front, being the one under/behind the bar on a Skyline.... but even for that one, trying to jack up on what amounts to a thin piece of steel, designed purely for withstanding a horizontal tension force, not a vertical compressive force (and so would be prone to buckling/crushing) and, my most particular bitch about it - located RIGHT AT THE EXTREME FRONT OF THE CAR, applying a load up through the radiator support panel, etc, with almost the entire mass of the car cantilevered between there and the rear wheels? Nope. Not doing that. Not on the regular. That structure out there in front of the front crossmember is not designed to carry load in the vertical direction. Not really designed to carry any load at all, really. The chassis rail that the tow point is connected to would be fine loaded in tension, as per towing. Not intended to carry the mass of the whole car, especially loaded all on one rail, with twisting and all sorts of shitty load distribution going on. No, I will happily drive up on some pieces of wood, thanks. That can only happen on driven wheels, and they are at the other end of the car, and this problem does not exist at that end of the car. And even then, I have been known to drive up on at least 1x piece of 2x8 each side at the rear, simply to reduce the amount of jack pumping necessary to get the car up high enough for the jack stands. What really really shits me about Skylines is the lack of decent places for chassis stands at either end of the car. You'd think they'd be designed into the crossmembers.
