Here are some ideas ;
* Sucking in your gut to activate the abbs (wrong). Instead stabilise the abs. pull air in (breathe in) and push the gut out
* not using glutes enough
* You are trying to squat too low with the low bar. If you don't have the extra hip flexibillity your back will round.
It will be your hip movement. Squats done right don't bugger up your lower back. Bad form is going to tell you in the lower back.
Also consider hamstrings could be too tight, in turn causing minor pelvic rotation > tight lower back muscles as they try to compensate/counter the pull from your hamstrings. This is almost certainly MY problem with lower back muscle pain.
Possibly, but I'd like to think I'm one of the more active stretchers/foam rollers here but that doesn't necessarily mean I'm being effective with the time spent or that there's not some other underlying issue that stretching doesn't fix.
I've found in the past that I usually have to "reset" which is normally take a week or two off aggravating motions, then begin specific work for the problem areas, it took me a good few years to get my elbow right after it was hammered from all the bro curls but now it's as good as it's ever been, it just takes time (hopefully not that long though as I've learned a lot about how to recovery from these sorts of things).
I'll get there.
Ugh making me open SAU on my farken laptop mate....goddamn.
Also unless it's Epic Meal Time or similar, I could guarantee you I'd be putting up a fight (comparing caloric intake in a sitting - not necessarily volume of food). I've made myself sick a couple of times when I did my silly bulk few months back lol
It's 10 mins long....could you give me a TL;DW rundown? haha 12,000+ calories in what timeframe? The whole day, or one sitting? Going by the thumbnail for the video, looks like there's ridiculous amount of cheese (fat) involved :D and dickloads of pasta/dough/bread.
I could do 12,000cal over a couple of hours with a few loaves of bread, couple of jars of peanut butter, and honey.....who needs protein PFFT!
4 cups of oatmeal with blueberries
1 kg of pasta
1 family / 1" pizza
2 large cheese and ham sandwiches
3 chocolate chip pancakes
3 French toasts
5 egg omelette
3 egg and cheese toasted sandwiches
5 rockstar energy drinks
42 minutes
Shiiiiiit.....hmm, I reckon if I prepared for it (and got really high) I could make quite the dent in that....but definitely not all of it in that timeframe. No f**king way.
And I wouldn't f**king touch those energy drinks. I'd sooner just eat tablespoons of sugar. At least then I wouldn't want to vomit (well, I would....but energy drinks are f**king rancid)
He's a professional eater; number 5 in the world, so I don't expect you to come close to anything he does lol
He did 120 Maccas chicken nuggets in 14 minutes...I get sick after 25.
Rockstar isn't bad, used to drink it in my LAN place days along with onion rings and milo bars.
There's a vid of a guy drinking 24k calories of olive oil. Definitely hit fat macro for the next month
The aftermath of that endeavour would've been unpleasant lol...I believe he mentioned in the video description that he'd been pissing oil out his ass for a few hours hahaha
Calories are easily piled of just eating high fatty shit. The days when I use to maul down a 1kg bag of honey roasted cashews a few times a week and spend most of the time in the toilet due to the extreme fibre punch. Not to mention it...I was a fat f**k
Edited by vspecIInur
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
