I was trying to go ATG as in calves touching hammys, basically as low as I can go, I find that easier than stopping half way down or a bit below parralell which feels like it would be a heap of pressure on the knees.
Not yet, considering it though. Current physio has me doing nerve glide/mobility exercises but after paying close attention during stretching etc I feel as though it's coming from the lower back.
been to a chiropractor?
my little brother had a back issue when he was younger, turned out his hip was out of place slightly resulting in one leg being longer then the other.
My legs are out by around 3cm every time I get trigger point :(
as low as you can go and as low as you can go with correct technique differ vastly. going ATG and compromising form isn't a good thing.
Even though you stretch etc. daily, do you feel you're making any significant progress? Maybe you need to review what you're doing if it isn't effective?
Buy starting strength or something that explains technique in depth, that way you can refer to it whenever you're in doubt to coach yourself.
I'm not sure if this will answer your question Dan, but I think these videos are worth a watch anyway. I watched them last night as I'm having an issue with my knee bending in during squats. It's a five part series called 'So you think you can squat' Here's a link to the first one
Easier to just go and see Matt again. All I need to know is if the butt should be rounding in under/tucking under naturally or whether that should be avoided.
I reckon that's a good idea.
I dont think It's natural to the squat, you're not squatting any lower, you're just pushing your arse down. That's my guess. I'll let someone in the know answer.
    • All my Polish car culture insight comes from watching Nightride. So I half expect this to get 1UZ swapped eventually?! Are you going to drive it in winter? I'm always curious how ATTESA would hold up in the snow. There isn't that much opportunity to try it in Australia.
    • My steering lock unit on my Infiniti G37 has failed. The car is a local 2012 Infiniti G37 (Q60 ) I need to replace the unit My local mechanic said i need to buy a complete steering wheel assembly. Does anybody no any mechanics in Gold Coast or Brisbane who can fix this issue or where i can buy just the Steering lock control unit. Thanks
    • thanks, will conduct myself accordingly. i unfortunately put about 150 miles on the car before reading this thread again, however no PS issues, and definitely no turbo issues. it spools normally and still feels fast to me, probably because my previous car was an N/A auto sedan...gonna go fix the PS vacuum line though lol. safe to say, got what i came to this thread for. thanks
    • Agreed, I've never seen a 260RS specific manual. As GTSBoy said it will mostly be stagea other than the engine loom https://www.hgeconsulting.com.au/stageaservicemanual.pdf
    • You'lll likely have to make do with R33 GTR for engine/tranny stuff, and Stagea for the body. I don't know that there's even been an actual diagram seen in the wild.
