I only do 2 body parts per visit eg Monday chest and bi's, Tuesday Back and Abs, Wednesday Rest, Thursday Shoulders and Tri's and Friday Legs ( Shudder ) I usually do 3 sets of 8 than 3 sets of weight where im failing before 6. I usually do a min of 3 different exercises for each area.
I should add that I am currently bulking and am not doing any cardio. ( also as I typing this Im eating chicken and sweet potato :)
Edited by Kenna802
Not if you're only doing 2 or 3 exercises in the session.
I only do two or three exercises in about that time but way less volume, two unfit for that shit haha
Ah fair enough, love sweet potato. Chicken and rice with some guacamole for flavour is nice too
Damn that's fast for that amount of volume
With volume training, as you're not always lifting extremely heavy weights / at your max, you can usually shorten your breaks and pump out lots of reps. It does tax the heart and lungs if you're not used to it, though; your head will certainly spin! My diet isn't fantastic; the volume training burns through calories and keeps me trim.
Also, Leesh, when I do 2-3 exercises it only takes me 45 minutes. If I was doing your workout I would be done in an hour or just over.
Well aren't you good
Fair enough, higher volume is something I might look into next year once I've hit some of my current goals
did my 1RMs today with my gym bros - a couple of months since I stopped doing bro splits and did the PTC beginner routine. Squat 200kg, DL 170 (one half assed rep at 180 but IMO it dosen't count), Bench 110kg. Weight loss has slowed down (now at 115kg, about 1kg per month), but very happy with my strength gains. I probably could have pushed the squat a little harder, but was not sure about my knees. No wraps, belts or gloves etc, only chalk.
Working on a 120kg bench and 200kg deadlift by the end of the year.
Interestingly my bro split mates were benching 150, but couldn't keep up with squats and only just managed to keep up with deadlift. I reminded them (like I do all split devotees), that squatting is so much easier when done 3x a week.
well everyone always complains about how sore they feel after 'leg' day, or squats day; I found that squatting 3 times a week means that I never have severe DOMS in the quads, glutes or anywhere else for that matter.
Oh I see. I don't get sore from squats anymore because I cant go heavy cos of knee bending in
Give it a shot and see if you like. Good for those who like a mental slog.
This. I don't get doms either unless its after returning from a week or two off...tomorrow for example
yeah my right knee caves in as I'm coming up from the squat
It's causing a hamstring strain too
weak adductors apparently
My adductors were pretty sore for the first few weeks of squatting 3x week, It went away and so did my knee bend. Might be a correlation there but given the amount you squat it would feel like doing a weeks worth in one session.
Most likely will once I reach my goals, not sure how long that will be, next year sometime hopefully
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
