To all you deadlift mofos
You guys haven't done a proper deadlift unless you use this fat 3" bar
I've done it in the past
It def helps your grip strength and lift more and next time you pick up an generic oly bar you will think its a tooth pick
how much does it weigh?
That's ol school thick bar btw
You can get lighter thick bars
I could barely use a 3" bar cuz I'm not tall and found that a 2" thick bar was best fit and weigh a lot less than that ol dinosaur bar (under 25kg)
Yeah fair enough. I like having a 20kg bar because It's easy for me to do my sets with 20kg and 10kg plates. I have 20's on each side for warmup, I then add 10's on, then I have 2 20's, then 2 20's and a 10 either side for my max weight. Then take the 10's off and do 100kg for volume.
good stuff.
I like the gym banner btw - makes perfect sense
haha yeah, dungeon rules.. I love the gym to bits
lol I used to call my old gym the dungeon (wasnt called that but that is what I refered it to as being)
Plain and simple - no spa, no yoga / pilates mambo jumbo, no sauna, weights were very old but useful with dumbels up to 50kg (not that I ever lifted that - but 40kg I did lol)
cardio equipment - basic stuff treadmil, stepper (one of favs), cross trainer (also a good one) and bike and rowing machines)
Was a great gym - and now I just realise how much I miss it :unsure:
Not one piece of cardio at dungeon, we only got a couple of mirrors the other day too
mirrors lol
You'll probably spend more time checkin yourself out than working out
Send them back and get more weights instead
Grip used to be my problem for deadlifts, giving out before my back did, but with mixed grip and chalk it's my back that gives out first.
So I won't have a bar of it Ants...know what I'm chalkin about?
could still try it - bar costs $40
Just drop weights off and see how you go
It will improve your grip
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
