To all you deadlift mofos
You guys haven't done a proper deadlift unless you use this fat 3" bar
I've done it in the past
It def helps your grip strength and lift more and next time you pick up an generic oly bar you will think its a tooth pick
how much does it weigh?
That's ol school thick bar btw
You can get lighter thick bars
I could barely use a 3" bar cuz I'm not tall and found that a 2" thick bar was best fit and weigh a lot less than that ol dinosaur bar (under 25kg)
Yeah fair enough. I like having a 20kg bar because It's easy for me to do my sets with 20kg and 10kg plates. I have 20's on each side for warmup, I then add 10's on, then I have 2 20's, then 2 20's and a 10 either side for my max weight. Then take the 10's off and do 100kg for volume.
good stuff.
I like the gym banner btw - makes perfect sense
haha yeah, dungeon rules.. I love the gym to bits
lol I used to call my old gym the dungeon (wasnt called that but that is what I refered it to as being)
Plain and simple - no spa, no yoga / pilates mambo jumbo, no sauna, weights were very old but useful with dumbels up to 50kg (not that I ever lifted that - but 40kg I did lol)
cardio equipment - basic stuff treadmil, stepper (one of favs), cross trainer (also a good one) and bike and rowing machines)
Was a great gym - and now I just realise how much I miss it :unsure:
Not one piece of cardio at dungeon, we only got a couple of mirrors the other day too
mirrors lol
You'll probably spend more time checkin yourself out than working out
Send them back and get more weights instead
Grip used to be my problem for deadlifts, giving out before my back did, but with mixed grip and chalk it's my back that gives out first.
So I won't have a bar of it Ants...know what I'm chalkin about?
could still try it - bar costs $40
Just drop weights off and see how you go
It will improve your grip
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
    • Gee she looks a bit rear heavy in that first pic! Sounds like a great project with the kids, but as I guess you know R series stuff is getting hard to find and pre that is pretty much impossible these days
