Have tried BN WPC chocolate, choc mint, mocha, banana. Chocolate is by far the best, banana is nice but very sweet, choc mint and mocha are average.
Have tried BN WPI chocolate, coffee and vanilla. Chocolate and coffee are nice and vanilla has no flavour to me really
Edited by Dani Boi
Do yourself a favour and do not try piña colada flavour, ugh
I think WPC has less or very little lactose in it, couple people I know have felt sick after consuming compared to WPI.
But yes WPI is more highly refined it's like skim milk versus full cream. Less fat but at what cost, the former is basically water. You get *slightly* more protein per gram from WPI, but if you're not lactose intolerant, WPC is probably more derivative of actual whey than WPI.
In short, I have no clue, but someone might know.
Assuming the lactose thing is accurate, the only logical justifications for buying WPI over WPC would be taste...and if you think that taste is worth paying 50% more (give or take) then by all means be my guest and throw your money away lol
People always say that, but if it is something that is consumed more often than not, why not enjoy it?
I'd prefer to pay $10 more a kg for eye fillet than blade steak.
For those people, I wholeheartedly side with Markos (and perhaps Tolga? Idk) that they're pissing their money down the drain relying FAR too heavily on supps. If you're consuming something in enough volume that the taste becomes a concern, I believe that would mean cost is of even greater concern due to increased turnover.
Creatine, krill oil and wpc are the only things I have.
Most of the time I forget to have the creatine.
I've given up on powerlifting due to too much time injured and yet still weak (comparatively).
Now lift what I want, how I want and am enjoying it more.
Currently eating a "winter diet" lol.
Going to do a 12-16 week cut closer to spring.
I did some curls, and I liked it... Hope my powerlifting friends don't mind it.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
