he didnt deserve to win, didnt have enough definition.
Heath had him in the arms, legs and abbs imo.
I actually rated Shawn Rhoden the most, but he wasnt big enough if that makes sense
Mag-10 is used for protein pulsing, (science based dosing strategy for making the body hyper responsive to high protein utilization and producing maximum anabolic effect) which is achieved by three to four amino acid spikes per day.
Plazma contains di and tripeptides and carbohydrate complex to increase metabolic rate and create a pump effect. It stimulates enhanced muscle responsiveness and is also used post workout for recovery
oh my god.
I think I just brained my damage reading that shit.
  • Like 2
squatted 200x3 out of stands yesterday, not my heaviest ever, but felt good given that it was all to depth, no wraps, sleeves or belt.
Gonna give sumo deadlift a go next cycle too, as it would appear to suit my build better. Still liking 5/3/1 BBB, but will likely change to 3/5/1 BBB for when I start competing next year.
Next challenge is to sign up at the Mrs' gym and show her to do the 4 main lifts, since her PT seemed to do everything but that.
Edited by bozodos
  • Like 1
oh my god.
its the power of bro-tien..... if it actuallly enhanced performance in any real way ,it would by definition become a banned substance.therefore making it lose cred, because believing in sups that are as powerful as roids is an essential part of believing like a bro.
however, since being a gym-bro isn't a sport (yet) any bro-curl-cred enhancing food is fair game. Backed up with plenty of bro-science and endorsed by website forums like bb.com and tnation its sure to be a winner in any gym-bros book.
hehe go Leesh stick it to the man.
decided im going to enter a powerlifting comp next year.
need to get my RMs up higher. Have been advised that to be competitive i need to go 140/100/180
major challenge for me will be the bench.
What weight class?
Bench should be at least 110 for your weight category
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
