Hello Everyone
Thought i'd share my work with everyone. I made an air box for my Apexi pod. I went to Bunnings got 0.5 mm aluminium, tin snips, hole saw, drill, G-clamp, hacksaw and a couple of other bits. I more ar less followed a tutorial from lingeringsoul. Thank you lingeringsoul!!
I got a piece of cardboard, made a template. I then tried fitting my cars bits to the template. After a bit of modifying.......tadaaaa! I placed template on aluminium, cut it out, rounded the edges and fitted it. I also made two brackets out of aluminium bar 20mm wide by 5mm thick. One for securing pod to car body the other to hold air box. Happy times. >_<
Updated with Insulation as per Recommendation, went to clarks rubber. Apparently it's used for firewall in engine bay ( was told by shop manager). $23 per metre. Should be heaps better now. Thanks for the hot tip GTST! :P
Edited by 1C3B3RG
https://www.sau.com.au/forums/topic/200940-air-box-for-pod/
are you going to insulate the box?
The aluminium will retain heat so once the engine is at operating temps, the engine bay wil be hot and the box will also get hot.
You can get insulated foam from Clarks Rubber.
costs fark all.
It's silver on one side and grey on the other..
just a thought if you must have a pod and air box.
also, I'm guessing the hole saw was for a cold air feed to the pod right? other wise it's pretty useless in there.
https://www.sau.com.au/forums/topic/200940-air-box-for-pod/#findComment-3575666
made a box for mine yesterday, using some fiberglass sheets that my dad had in his shed.
started out out useing a sheet of card board, and cuting it to shape to use as a template.
once we had got it to the right shape we bolted it in place useing the mounts for the old air box, and then filled in the gaps with silicone.
then made a lid that screws in to place.
then painted it.
done, took about 5 hours total.
https://www.sau.com.au/forums/topic/200940-air-box-for-pod/#findComment-3579119
nice job guys I have posted mine on here aswell, I have not gone all the way to the ground on the left , but pretty close I will possible put insulation on it if it ade a big difference, but I need to get my hole cute under my pods, i have a few things to get around in my car and my steel skills aint that good :|
Edited by Mark0
https://www.sau.com.au/forums/topic/200940-air-box-for-pod/#findComment-3579917
hey did you get the foam with the glue on it or buy gle, if you bought it what did you get that will stick with the heat, i wanted to get the 0.5 ml stuff/
cheers
Hey dude, make sure you get some sort of automotive glue or silastic type stuff, it must be heat resistant and best if also oil resistant. Coz if that baby catches flame at the air intake you gonna have 4th of july for real!!!! :P Happy motoring.
To all the guys posting thier airbox pics, well done, excellent work, good to see. :D
https://www.sau.com.au/forums/topic/200940-air-box-for-pod/#findComment-3581396
    • You just need to remove the compressor housing, not the entire turbo. I would not be drilling and tapping anything with the housing still on anyways.
    • So, I put my boat on a boat. First of all, I'm going to come out and say it. Why is Tasmania not considered a holy goal, an apex that all road-legal modified cars go to, to experience? This place is an absolute wonderland of titanic proportions. If people are already getting club runs for once in a lifetime 30 person cruises to Tassy then I've never seemed to see it. It is like someone replaced the entire place with an idyllic wonderland for cars, and all of the people living there with paid actors who are kind, humble, and friendly. Dear god. After doing a lap of almost all of the place I've found that it's a great way to find out all of the little things that the car isn't doing quite right and a great way to figure it all out. All in all, I drove for 4 hours a day for a week and nothing broke. I didn't even need to open the engine bay. This is by all means a great success, but it has left me with a list of things to potentially address. I also now have a 3D printed wheel fitment tool which annoyingly hasn't got any threads in it to actually assemble it. I might be able to tape it together to check the sizing I actually want to use, but it'll likely involving pulling the shocks out to properly measure travel at least at the front, and probably raise the car while I'm at it, at least in the rear. I scraped on quite a few things and I'm not sure how else to go about it. I was taking anything with a bump at what felt like 89 degree angles. And address those 10 other tasks. And wash the car. God damn it is dirty. And somehow, the weather was perfect the entire time - And because I was on the top of Mt Wellington it turns out it was very much about to freeze up there. I did something I typically never do and took some photos up there in what must have been -10 and the foggy felt like suspended ice, rather than mere fog. If you own a car in Australia, you owe it to yourself to do it.
    • Damn that was hilarious, and a bit embarrassing for skylines in general 😂 vintage car life ey. That R33 really stomped. Pretty entertaining stuff
    • Hi, I have a r32 gtr transmission. Does any of you guys have an idea how much power it will hold with the billet center plate and stock gearset? At what power level and use did yours brake with or without billet plate? Thanks, Oystein Lovik
    • Saw this replica police car based on a Mitsubishi Starion XX parked next to a 'police box' (it's literally a box) in Hirohata, Himeji City in Hyogo prefecture the other day. It's owned by Morii-san who is a local Mitsubishi Starion enthusiast. According to a local radio station blog post, he always wanted to make a police car himself based on ones he saw in his favourite Manga comics.  As it's illegal to modify a car to look like a police car and drive on the road, Morii-san tried many times to get permission from Aboshi police station headquarters nearby. They refused initially by after they got tired of that they granted him permission. However, the car can only be displayed on private property and obviously can't be registered as long as the police livery is present. The car was completed at a cost of 1.5 million yen (US$ 10,000) in addition to the car cost. A location was chosen outside Hirohata Police box where the car can easily been seen from the street. Morii-san has two other Starion road cars, both widebody GSR-VRs.
