Currently Im running a dual diafram clutchnet PP with 6puc sprung disk and a fidanza ally flywheel, thing shudders A LOT, its not a very nice formualtion they used for the disk pad's. For now it has been ok, land up with a very sore left foot and battle to pull away in the wet or up my driveway without chriping the tires.
I am not looking towards somthing with lighter clutch pedal effort, and slightly more HP capability to suit the new motor with around 400kw, Been looking at some twin plate's and from previous experience with the old school twin plates it leaves me with a sour taste, is there anything on the market you guys use that is not to brutal with shudder and clutch load yet can hold some decent power? Did a search but couldnt find anything useful.
The car is used on the street with very ocasional track usage, and the odd drag with fairly small M/T ET streets
Thanks
Thanks
tripple plate OS giken is the g-o, tuff as nails and they dont shudder
What is the pedal weight like? I need somthing that wont kill me in a little bit of traffic, I nengun dont sell them, any idea who does or rough price idea?
Take a look at the Nismo Super Coppermix twin plate, i haven't personally used it but from what i hear its very similar to a standard organic clutch in terms of drive ability around town and is rated for 600hp.
http://www.nengun.com/nismo/super-coppermi...in-plate-clutch
ATS carbon twin plate
is the stuff factory pedal soft just no slip
They are a touch out of my budget unfortunatly,
Looks like a toss up between the Nismo supercoppermix twin and the ORC 709, has anyone got first hand experience with the orc 709?
Contact jim berry in Bris. He made me an organic clutch for my gtr. done heaps of launches and a couple of sprint meets & hasnt let me down. easy to use in traffic & light under foot, doesnt shudder either.
People go overboard with expensive twin, triple & button clutches but it isnt required or practical for most applications.
It only cost me about $350 too.
iv got a orc 2win plate button, its light under the foot, a lil noisy when u step on it, but takes a long time to get use to and not the best on hils or ups n downs or TRAFIC. in fact its real bitch to park in tight spots but u get use to it how ever i always avoid trafic even if it means ill just sit n have a drink till 6 .. not worth the head ache..
might try the nismos next to see..
  • 1 year later...
I had huge problems in my old 33. Went through 2 exedy's under wty then gave up. My old man who is a mechanic got me onto somebody in lismore he has known for 30+ years that did an awesome job on a nice single for me. Held my 345rwkw no problems no matter how i drove it :)
Have a chat to Dave Write on 0266216495. Best thing i ever done. Cheap, quick and he said he builds a few big hp skyline clutches for a few workshops in sydney
Edited by coaster
I'm using an NPC single to hold around the horsepower you are looking to make. Pedal weight is as light if not lighter than stock. Its a bit sudden but quite easy to control once you learn it.
Kills the berry single I had prior to this. Berry clutch was just as grabby but way heavier pedal and with less clamping pressure than the NPC.
been more than 18 months now since I went with the Nismo supercopper mix twin plate, best clutch I have ever used! and as with all things car I landed up with 150kw more than antisipated in the power department... The Nismo clutch feels no pain when the T04z is at full tilt.
I stripped it out last week to change the N1 oil pump, clutch after 20 000km's of abuse still looks like new. Still running as smooth as stock and the only con is a tiny little bit heavier than stock clutch, probably within 10%.
Sounds to me like you've answered your own question. :P
    • Hey guys Long time lurker, I daily a nm35 stagea 250t rs four and I've had it for almost 2 years (very reliable 👌). Issues or just looking for information ill always find myself here having a read, so thought id join.  3inch stainless intake, pod filter, AM performance turbo dump pipe, 3inch hotdog, 3 and half inch stainless to 3 and half inch AM performance blast pipes. Bc racing coilovers. 18inch rims Hdi intercooler and trans cooler soon.  Here's my car
    • thanks for the advice on the box... i was thinking the 6 speed was better for cruising on the highway but on closer inspection and comparison the Rb 5 speed box was not too different...  So the choice is going to be the RB25 box... if I can save up and find one at the right price
    • Thanks Matt, yes that's what i am aiming for. Just going to apply the right voltage and grounds to the dash connector. Hence my search for these pins... any chance you know if these pins are in the same spot as the ones on the S15 Dash connector? as mentioned above on page 8?
    • Yes, unfortunately that's the one. Signal was noisy to begin with; after driving once and looking back at the logs I saw pressure constantly swinging between 0-200psi, or staying at 0 randomly for a few seconds. There's a lot of good sensors that share the same look and feel, so don't presume they're all bad. I bought mine for 20$ off Amazon and I should have read the reviews prior, as it's clear they're junk.  I purchased a lowdollerr motorsports sensor.
    • wedding eh.....I seem to get to more funerals than weddings or christenings these days....
