  • Replies 607
Posted Images
kk cool jase.
ill stop around 630 to get some maccas.
if i see ya ill wait up. cheers.
silver 34 here. ill prolly park in front of maccas.
either way ill see u tonight! :)
cheers,
Shane
Just got back! Great to see and meet some new people. A special thank you really does have to go to Loz for so creatively going the complete wrong way and seperating 4 cars (including myself...doh!) from the main pack after leaving mt keirra... then pulling over where trucks are screaming down a corner so we can all die. Was home time anyway. Good fun! :D
On that note do you think you could have braked any harder? i nearly earned myself a new hood ornament...
Aside from the whole separation thing was a v good night.
Nice to meet so many of you!! Was an awesome turn out :D
I had a great time and was loads of fun and I loved hearing all the stories at the end where everyone went the wrong way and all got lost! LOL
The lookout was really pretty and was a good finish to the night!
Thanks to everyone that came along.. Hope to see you again :banana:
P.s Will be organizing another meet next month in Feb and will more then likely be a nice sat/sunday arvo cruise and spot of lunch on the way...Thoughts?
Sorry about leading everyone the wrong way down the mountian last night. I noticed when I got to the HWY I came the wrong way but saw the Picton Rd exit just down the road and thought great we can do a u-turn there and head down to maccas, so Albert an Brendon followed and I asumed everyone would maybe turned around and eventually come down the mountian, but got a text from Jess saying otherwise. Well that was cool cause after we got to maccas to Cop cars and an unmarked one turned up to get some dinner I assume but I thought what would have happened if we all turned up!
I did have a great night and was great to meet all of you. :D
Thanks again to Jess for organising, See you all again soon :banana:
Oh who has PIC's from last night?
Drive safely, Joe.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
