Hey guys, had my car dyno's was expecting a little more but anywayz, though maybe we could have a discussion on here =D
RB25DET
GReddy Intake
80mm TB
FMIC
3" intake pipe
BOV
Billet fuel rail
550cc Inj
Bosche 910 pump
surge tank
Sard Reg
high flow fttings etc
GT30R .82r
kazama manifold
44mm Gate
3" system
splitfire coils
EMS 4424 stinger
Auto box, had a manual valve body but box i believe was slipping at time of tune
330rwhp @ 16.5psi
think something is wrong? or do i need to retune once i get my properly built box back from top quality transmissions?
https://www.sau.com.au/forums/topic/201493-rb25-power-output-low-or-avergae/
I wouldn't be trying for too much more than that out of a standard? 25. There are some that can reach the high 300's & maybe a bit over, but it is risky & it depends how it's driven.
From what I read, I was under the impression that by 300rwhp the RB25 would be on a knife's edge for reliability....
Hmmm....
i have been running 335rwhp now for over 6months without a problem, (most likely longer just cant remember), also ive taken it to the track more than once and had a full drift pract day at the track without a problem :)
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
