... ok, whoring aside..
The ADR regs specify 100mm at the lowest point of the car. That said, my flatmate's Lancer MR is pretty much factory, and its front bar is lower than mine. I also regularly see even cop cars with their exhausts only a few mm off the ground which wouldn't be legal.
Unfortunately driving an import you will get done for it eventually, and its one of the most regularly policed defects from what i see. One rule for any boring old car, another for nice cars it seems.
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-432274
omg fulllllly lowwerrrdddd bro
lol 2GU UP, why do you want to drop it so hard? all it does is give you a shit ride quality and make the car that much harder to drive. honestly people arent all that impressed just because your car is scraping its gut across the pavement... why dont you pump some money into whats under the bonnet, not under the fully sick rimz :mad:
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-433230
dude I'm sure with a set of height adjustable coil overs you could get your car somewhere near that level of lowness
I've got a mate with a 32 and with his adjustables his rims sit inside his arches.Maybe not that much but they do. Apparently you can modify something on the coilovers to make them go lower too.
I'm no expert, in fact I don't really know much at all about coilovers, but I'd say that's the only way to go.
Hope that's something useful for you.
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-433333
badman - im putting money in to the engine too dont worry i just luv my cars as low as possible and when it was sitting on its bump stops everyone luved the look of it ive driving cars that arenoly about 50mm from the ground mine was 75mm and i dont find it that hard to drive
believe it or not all the ppl ive spoken to about it have said that they luv it when its low as
JiMiH - thanks man i think ill just go the KMACs they reckon u get a 4 inch drop so guess ill see wat happens
apparently shortened shocks can be used as well not 100% sure how good they are though
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-433448
Australian civil engineering standards specify that nothing shall project 100mm past the level finished surface of a roadway and that the maximum change in gradient is 13%, which means 99% of cars set 100mm above road surface will clear this change in grade and any speed humps etc.... so i'd set teh car at 100mm high. ( i'm pretty sure it teh law in qld and all other states). hope this helps :)
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-434270
careful with bags man, a bloke i know put bags in his rodeo and thought it was all sweet, turns out his install was completely illegal and now it's been defected off the roads
im not quite sure why exactly, but his install quality wasnt exactly the best ever (they put the compressor where his aircon used to be, the switch box was the shittiest thing i ever seen)
so just be careful where u go to get bags ay, keep it all legal and make sure they kno what they doin
https://www.sau.com.au/forums/topic/20191-how-low-can-i-go/#findComment-450623
    • I'd be very surprised if you can buy new OEM mats. But if you can, I want some too!  Do you have links to the variations you found? Also, where are you located? I found that Nengun is happy to list items to purchase but when you do buy them you'll get an email that it's actually discontinued. As far as I know the variations in floor mats are different colour schemes as well as automatic and manual having a slightly different shape. The automatic ones fit into a manual car without issues, but I think you'd have trouble fitting the other way around. I have photos that show the shape difference if you care. FWIW I bought sets of used floor mats in decent condition at yahoo auctions.
    • Hi 🙋‍♂️. Just bought my Unicorn but the interior need some minor work so it would match my expectations ;). I noticed it is hard to get used oem floor mats in good condition so i started to dig if there's any chance to buy set of new ones. I found two websites - nengun and amayama and it looks like one can still buy factory new floor mats in Japan, but thers a small issue. Some mats (i assume genuine, oem ones) are marked as G4900 and these are "discontinued". The ones you can buy are marked as G4911 but i have no idea if these are also oem, made by other producer or some lower quality replacements that looks entirely different. Can anyone help? 😃  P.s. there is also some strange indication - 0V005, 0V015 and 0V505. Any idea what does it mean? Would appreciate any help with this 🙏
    • Hi, Marek here 🙋‍♂️. I finally fulfilled my longtime dream - recently bought Stagea and now waiting for it to arrive in Poland. There's only few of these in my country, and one of the owners  recommended mi this forum as a source of all the info i'd need since now i own one  so here i am.
    • Version 1 aluminium airbox is.......not acceptable No pics as I "didn't like the look.....alot" Even after all my "CAD", and measurements, the leg near the fusebox just didn't sit right as it ended up about 10mm long and made the angle of the dangle look wrong, the height was a little short as well, meh, I wasn't that confident that Version 1 was going to be an instant winner I might give Version 2 another go, there's plenty of aluminium at work, but, after having in on and off a few times, and laying in the old OEM airbox without the new pod filter and MAF, there may be an option to modify the OEM air box and still use the Autoexe front cover and filter.... maybe This >  Needs to fit in here, but using the panel, and not the pod, the MAF will need to fit in the airbox though> I'm thinking as the old OEM box and Autoexe cover that is sitting in the shed is just sitting around doing nothing, and they are relatively abundant and cheap to replace if I mess it up and need another, it may well fit with some modifications to how the Autoexe brackets mounts to the rad support, and some dremiling to move it get in there, should give me some more room for activities, as I don't want to move the MAF and affect the tune Sealing the hole it requires to stick it in the air box is simple, a tight fit and some pinch weld will seal it up tight  I am calling this a later problem though
    • and it ends up being already priced in as though you're just on 91RON without any ethanol. Car will lose a bit of economy as the short and long term fuel trims bring down the AFR back to stoich or whatever it is for cruise/idle for the engine.
