Just wondering if theres any interest in having another dyno day? As I need a dyno run myself. Would be a good get together too.
If not will book in one afternoon myself.
Dyno day is booked for the 8th of March 9am.
I just need to go in and have a chat to the guys. Will need to confirm how many r33 gtrs are taking part, as they take a while to setup. Also if other people are interested, rexes take some time, so too many of them are not too good.
Looking at a max of 30 cars, don't think we'll reach that many though lol.
Cost will be 50$ + 5$ donation to sau.
Just a note to all. All money will be payed to ESP on the day, won't be passing through my hands. 5$ is an appreciated donation so to speak. Just with all this PL stuff nowadays want to cover myself. I will be going through the list later, but ALL R33 GTR's will be grouped together (if we have multiples), due to what ESP has to do to get them running on the dyno
On the dyno day note. I know my car won't be the most powerful out there. While it would be good if we win vs the supras, it's the day itself that counts
Extreme Street Performance U1/ 171 Gilmore Rd Queanbeyan 2620(02) 6299 4444
Clicky da linky for da map...
http://www.whereis.com/whereis/retrieveEma...482719484114436
https://www.sau.com.au/forums/topic/201947-dyno-day-8th-march-esp-in-qbn/
  • Replies 237
Would probably look to run one with the Supra boys in a few months, not sure on the interest sooner.
Whilst it will be a little while before the heat of Summer fades (read: not conducive to turbo'd cars & dyno results...), IF there is enough interest, I'll put my hand up to organise a dyno day in late Feb' or March. If the Supra Club has someone reading this, or if anyone knows a contact in their club, I have a good, GOOD location/ setup in mind...
Called Ed quickly at Autotech, looking at at least 5-7 people for a dyno day, Around 50$ a vehicle, maximum 15-20 cars. May be able to make a few alternations on our cars while on the dyno too. Now I'd have to ring back and confirm dates and the charge, but this is a guide. I've had a run on the dyno there before, and they are a great bunch of guys.
So post up the interest for Autotech or I can ring ESP if someone has their number.
I'm really only after a run to see the basic tune for my car at the moment, will be then getting a new remap done, and dyno the car in a few weeks time.
ESP - 6299 4444
Ask for Glenn or Daniel.
That's where I was going to suggest. If you do call, say Jayce & Erica (along with Mick!) suggested them! I like the AutoTech guys, too, but ESP's is an AWD dyno, and know they were keen to get a day happening...
Yeah up to everybody, just rang ESP, 50$ for a dyno run, minumum 10 cars. I normally run my gts4 on the autotech dyno in 2wd mode, but of course its a 32.
So post your serious interest. At least 5-7 for autotech or 10 for ESP
CeJay - Autotech or ESP.
edit forgot to mention that, but did say someone from SAU put me on to them.
    • To plug the hole. The engine plant may not have known whether the car it was going into had a gauge or not. It was a long time ago and the integrations might not have been fully modern. Or they might not have cared because the extra inventory and processes to save a few cents on the sender might have cost more anyway. But please tell me you are not still confusing the idea of a pressure gauge sender, and an oil pressure light switch. The switch will be out there. In a separate hole. Probably with only one wire running to it. Running the light.
    • Blower needs to go low on the exhaust side, displacing the AC and PS, which you have to decide whether you want to keep and how and where to relocate if you do. Electric option for PS is, at least, helpful. Sadly, there is no workable 12V electric AC of any value. Whilst the blower is the last compression step before the throttle, and so it might seem a good idea to have it near the inlet manifold (as mentioned above), you probably want it to go through an intercooler first, so, having it on the opposite side of the car facilitates that air flow path. The turbo discharges into the blower, so proximity of the turbo's compressor outlet to the blower's inlet is nice. But then you might want to intercool that too, before boosting it again....which would probably be a ball ache. Routing pipes out to the front and back could be a bit shit. If there was room for (at least) a small (but preferably larger) water to air core on that side, then that would probably be the best approach. I guess a reasonable alternative would be to locate the blower where the alternator is (more or less, associated with the inlet manifold, per Matt's thought), and somehow incorporate a water to air core into the manifold, sort of like they do for modern blown V8s. The big difference here though is that those V8s have only the one throttle (upstream the blower) and only the one compression step (the blower) and no need for too much in the way of bypass/blowoff valves. Whereas in a twin charged 6, you do need to think about one or two bypass valves associated with the 2 compressors and you would prefer to have the intercooling done before the air has to pass through the throttle. You'd like the throttle to work approx the same no matter what the compression is doing. But if it is located in hot air stream before a cooler, then sometimes the air will be real hot, sometimes it will be quite cool, and the throttle mapping/response will be quite different between those two cases. The throttle, if sized for hot air, would be too large for cold conditions. It's all a ball ache.
    • Package SC on exhaust side. Remote mount turbo. Still a fair bit of room when you get creative on the inlet side of the motor too. Especially if you can get really creative with the welding, and effectively build it into the bottom of the inlet manifold. Would definitely take some design work, and some trial and error, to make sure flow works well still! Might be easier to just start with the Nissan March though... All the work is already done for you...
    • I'll sit down and get a post together 😁
    • The factory oil pressure sender is no longer in the car that's what is confusing me. In the Taarks adapter I have an aftermarket Bosch style pressure/temp sender and the factory temp sender only. Oil pressure is perfect. Where does the factory oil temp sender go to if there were never any gauges? Why was it there from the factory?
