  • Replies 237
lol
with over 200 killa wasps !!!!!!!!!!!!!!!!!!!!!!!111111111 from rb20 YO
sif a soccer mum could handle teh power of teh 4 door :P
hmmphhh :down: I'm a soccer mum and I drive an RB20 4 door in the hillclimb
go see www.sdmahillclimb.com and see the results where this soccer mum wins with the 4dr :P
Then watch the soccer mum round up the boys at Wakie with her fairly stock little 4dr... where she had to keep stopping for him while he regains control of his vehicle (rules = only allowed to overtake on straights).
http://www.youtube.com/watch?v=7inn0WBvI1s
Dont tell this soccer mum that she couldn't handle the powah :D cos this soccer mum is thinking about selling the rb20 4dr cos it doesn't have as much powah as this soccer mums other cars LOL
Now get ur @ss :) back up here and get to the Dyno Day!
Hi Michelle,
what times were you posting on those laps? power to you for observing the rules, that what makes the difference between a good and bad track day.
cheers
hmmphhh :P I'm a soccer mum and I drive an RB20 4 door in the hillclimb
Now get ur @ss :down: back up here and get to the Dyno Day!
yeh but thats ur 4 door
my 4 door has POWA :)
and yes maam ill be there :P
although i need address details
Extreme Street Performance U1/ 171 Gilmore Rd Queanbeyan 2620(02) 6299 4444
Clicky da linky for da map...
http://www.whereis.com/whereis/retrieveEma...482719484114436
Hi Michelle,
cheers
I don't know the times... it wasn't a timed event :D but it was a terrific day though :)
my 4 door has POWA :yes:
Yeah, but I still love driving my li'l 4 door, she's fun. I'm only selling because I have too many cars and not enough spaces, unless someone has a garage they're not using?
well ive got space and wouldnt mind another 4 door in the garage,
but i dont think youll like a 6 hour drive just to pickup your car :yes:
thanks :D
LOL I knew you were gonna say that... BRAT!!!
You should of let us hear just the engine note!
Music on a race track is a no no...
The reason I put music was because there was a horrible clunking noise all through the clip, it was the first time I used the helmet cam - I later identified it was the battery moving, once I gaffed that up the noise stopped.
Trust me, the music was the better choice this time.
sif the rb will out sound any moving battery :thanks:
    • I’m here solo don’t have any hands to help so haven’t hit it with a timing light
    • When you crank your car, and hit it with a timing light, can you see a steady crank timing?
    • Oh, forgot to add, A few months ago I was getting mixture codes and the car was using crap loads of fuel. You could smell the unburned fuel in the exhaust, it was crazy strong. Economy was over 17.5 l/100 and usually around 19. I smoked the engine and found a leaky CCV hose which I replaced and then I replaced my two pre cat O2 sensors, I also replaced the MAF. This fixed my mixture codes and improved my exonomy but I'm still 14 - 15 l/100 when pottering about town so something is still amiss. Throttle response is much better and it has more pep but I'd like to know why it's still so thirsty (and I'm hoping that whatever it is gives me a bit more poke).
    • Car is on factory injectors/z32 maf/ q45 throttle body/ z32 ecu with nistune
    • Hello all, currently finishing up a rb25 swap into my s14. Having issues with starting, car has spark (confirmed by pulling a plug and watching it spark), has fuel(confirmed by checking pulse/voltage at injectors all spark plugs are soaked in fuel). Car cranks over and pops into the exhaust with a heavy fuel smell but no attempt to start or run, I have torn the timing cover off and triple confirmed timing, turned the CAS in multiple spots both directions, attempted to start with coolant temp and maf unplugged, checked my fuel lines and made sure they weren’t backwards, checked voltage at cas/injectors/coilpacks, made sure all the grounds in the harness are connected and added a few grounding straps (1 from chassis to block, 1 from chassis to head, and 1 from chassis to igniter chip) I am getting stumped here. As a last ditch effort I made a full grounding harness tonight that’s going to run from the battery and add an extra ground from the battery onto the coil pack harness/igniter chip/ intake manifold/ Wiring specialties harness ground/ and alternator. I’m hoping maybe the grounding harness will fix it here but posting here to see if anyone has any other ideas on what else I can check. My fuel pressure is unknown right gauge will be here tomorrow.  IMG_3206.mov
