cool mate, I am sure it will all work out for you.
FYI it doesn't matter that the wheels are the same dimensions - they HAVE to be oem parts. No ifs ands or buts. So if the compliance workshop doesn't have evidence for the exact part numbers of every single item in your car, they will have to do the evidence themselves (= mega $$$) or hopefully they can swap them for non-N series parts.
When does she get here? I am very keen to see it in the flesh!
Due here in 4 weeks then 4 weeks for compliance etc, its cool they have a stock Caldina with all the parts they need to get it through, and it also has all the stock parts in the car anyway.
  • Replies 58
Posted Images
Sounds like a nice ride. out of interest, what made you go the Caldina over the Legnum (or Stagea)?
You mentioned fuel consumption, but I wouldnt imagine it to be that much different to a skyline... 200kw requires a reasonable amount of fuel regardless of 4 or 6 cylinders?
Can you believe that the Caldina uses 9.0 litres per 100klm now the 33 or 34 skyline is around 14 per 100kms!
Cheaper to run register and insure but still packs a punch.
Why did i choose this over a legnum?
Legnum is a v6 twin turbo with about 170kw and an outdated galant look and feel.
Legnums are less powerfull, more expensive to run register and insure.
And no one else has an N Series Caldina... dare to be different i guess.
Bah, as if Legnum sounds like a vegetable :D
Reason I was asking is because I just bought a Legnum from Auction in Japan last week. Now the wait begins!
I agree with Mitchy - I much prefer the look of the Legnum, but no doubt your car will be unique Cell :D
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
