hey team
who has experience with night club photography?
i'm looking for a new lens for shots of groups of people
a camera store recommended a 30mm fixed. f1.4
would this be wide enough?
it sounds ok because of the f1.4 so i wouldnt have to use my speed light too much.
would like to take shots like this
currently am using
nikon d100
tamron 28-300mm
nikon sb-800 speedlight (external flash for cherie)
https://www.sau.com.au/forums/topic/202068-nightclub-shots/
That shot was definitely taken with a speedlight, with a dome/diffuser on it so that it didn't create harsh shadows. Rear/slow sync was also used as you can see it has exposed the shot for maybe 1/4 second (it has softened/blurred a little in the background) and then "snapped" the subjects in the foreground.
Shooting without a speed light wouldn't look as "pleasing" - in all senses of the word. :(
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3590399
Shooting without a speed light wouldn't look as "pleasing" - in all senses of the word. :D
thanks mate.
do you think i should go for the 30mm fixed lens? or try out the 28-300 with a speed light?
will use the diffuser on the speed light also. pointed at 45 degrees. i like the slow sync for the background effect
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3591312
its been shot with a very slow shutter speed, which is why the background is clear. A wide lens is best as most times your shooting groups of people
I would be going for something like a 12-24mm or 10-20mm lens
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3591464
i dont think the skanks going to these clubs want to see pictures of themselves with their heads all stretched out of proportion
the wide end of those two wouldn't get used very often......
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3591510
20-25 gives good area exp...f1.4 is needed for darker settings...any strong flash with diffuser would be good...
try at home and then try..say...around a servo etc..then fiddle with your settings and go for it!!!
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3591752
lol "hai ma'am for buying a twix u get ur photo taken!"
https://www.sau.com.au/forums/topic/202068-nightclub-shots/#findComment-3594554
    • With the system, once you drive it for a bit, and before you turn the car off, does the car fix its date and time? When you say the date is wrong, what date does the vehicle think it is, and does it always show the same date? My thoughts from a process driven view is; The system may be defaulting to a standard start date/time. The main reason you'd typically see this occuring, is the system is losing its constant/backup power supply.   If its always defaulting to the same date/time at start up, and especially if it fixes itself while driving, I'd say either the non volatile memory has an issue, or the power supply to the volatile memory that stores this information.   The other thing I'd check is if there is anywhere in the system you can adjust the date and time from. If the date/time is still moving forward since it wished you happy new year, then it is 100% possible the system has just had a bit of data corruption occur, and you likely need to find a way to reset the date/time in the vehicle.
    • Scissor Jacks are an accident waiting to happen, the only time they should be used are in an roadside flat, even then a tyre and rim should be placed underneath
    • You know how your car rolled through a fence in your last jacking escapade? Scissor jacks increase the likely hood of that sort of thing happening immensely!
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
