Thanks for everyone who has posted, it's great to see such a positive response. So far it's looking like a monday or wednesday night, so if you haven't posted yet and have a preference please do so by tomorrow night.
Qikr33 - thanks for the offer. At this stage the officer who has contacted me was a hoon squad sargent, who does field work (as in chasing people around). He also mentioned he can bring a police mechanic, so I will confirm this with him when I next speak to him. I'll let you know how it goes.
Boxhead - yes, I'll be happy to take notes. I actually want to see if we can get documentation we can copy from the police on this, and also take minutes and get the police to then "sign off" on them to say that's what happened.
Bryanlee - thanks for the offer. I'm not sure we should video it, but I will suggest it to the guy next time I speak to him. Are you coming? Wasn't sure from your post.
Krys - are you coming or toasting someone?
Ok, please post if you haven't done so already and advise availability. After tomorrow I will persue the venue and confirm that, and also being asking for questions to be submitted as it would be good to give these guys some notice of what we are after.
Thanks again to all.
D
https://www.sau.com.au/forums/topic/20242-modifications-vs-legalities-qa-night/
I won't be able to make it (I'm in Toowoomba during the week) but good luck with the meeting, and I must say that it's fantastic to see someone taking POSITIVE steps toward legal modifications. It makes a nice change to the constant bitching about "dam piggaz, jus got dun" - complete with dodgy spelling ;)
A couple of questions for them though:
1. Is it possible for a pod filter to be legal outside of a sealed box if it's engineered? If so, are there any further requirements?
2. In QLD, what is the story with aftermarket ECUs? Does it just have to pass roadside emissions tests, or does it have to go through some kind of re-compliancing? Is programmable injection OK?
3. What about intercoolers?
Thanks all for your suggestions so far. This is what's new:
1. It will be on a monday night
2. The venue is sorted - Bob Jane Toombul
3. Start time aiming for 6pm for food, with 6.30 kick-off
I will be rining the police to confirm a date, hopefully tomorrow. I am looking to do this on the 18th or 25th of next month, depending on the availability of the police.
As soon as there is a date set I will setup a new thread with a list of names of people coming, and then open it up for questions to be submitted. I would like to send them into the police a week before hand so they can research if required.
Thanks again to all who have posted. Feel free to post in here if you can make it, or if you now can't. I hope to be able to have the final date and time up by the weekend.
Thanks
D
good shit....wish we could organise similar in VIC..
guess the laws are different.. but will be interested in the feedback and the attitude presented by the cops. Notes i will be interested to read, for general consumption.
Originally posted by Boxhead
seeing as the hoon squad will be at this meeting, can someone get the notes, ill be using that night to do some illegal street racing :D
ROFL
Put me down Dave,
I should be able to make it with notice :D
Michael
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
    • I suppose it was relatively stock too, the JZ motor handle most mods thrown at them without even breaking a sweat
    • I saw your intro update, are you sure you've actually had a starter motor failure? You mention it could be the alarm causing it. I'm assuming you've got a no start issue, but what are the exact symptoms, as there could be a few reasons it has stopped wanting to start.
