come on guys lets get together and welcome these fellas melbourne style!!!
When: this friday 25/1/08 at 7.00pm
Where: Kmart campbellfield (crnr hume hwy and mahoneys rd)
Meet at 6.30pm at Kmart car park just under the big sign there and we'll leave at 7.00pm to a second meet point of lorimer st docklands right where subaru is and meet these guys there.
we should be at the second meet point by 8.00 so if people want to go straight there feel free to do so.
LEAVING DOCKLANDS AT 8.30PM SHARP!!! to the NS.com meet point
NOTE: just a slight change to the SECOND meet point instead of being under the bolte bridge we'll meet on hartley st just of lorimer st where subaru is.
and a slight change of time aswell as i will be heading down south to the NS.com cruise with the SA guys so if peoples want to cruise with us to that we're only going down for the meet.
i apologise for the changes and lack of planning guys but it was a last min thing so please be on time because we're leaving each meet point at the exact time
Whos coming:
me
GTS-T sedan
eddieeeee-ro +1
rushs
b3za
alexk
Basti
voox
Not sure:
bluey33
R33GOD
SLYNE
emsta2003 in his civic
DNGRUS
Wyseman
KIRAS
Edited by assyrian4evaa
https://www.sau.com.au/forums/topic/202657-meet-n-greet-friday-250108/
  • Replies 95
Whats the actual plans?
Where we going?
What we doing? (going to bar? somewhere to talk? or just a cruise?)
May be interested!
well wer catching up with the guys coming down from sa and each other but there is a plan to get down to an NS.com cruise but that will be decided on the day
Where we going?
May be interested!
Its the NS.com crews cruise.
More details see the thread on their website.
http://www.nissansilvia.com/forums/index.p...howtopic=281059
Where abouts on lorimer st? i work at the end near the westgate bridge. i'll be working till 830ish fri night
just under the bolte bridge mate. so your coming?
get my car back 2morrow, put me down + 1 for the moment. see how the weather is.
added
hi guys im the one who organised the cruise to vic and we want to go see the cars for the ns.com cruise but unsure if we will go on the cruise as we would have just been driving for over 8 hours so please come to the meet and greet there is 3 cars maybe 4 we are very excited on coming and we would like to do a cruise with you guys maybe saturday night so i hope to see you guys friday night x x
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
