Reading the latest version of evo I thought to myself Vector rings a bell.
Anyway here are the specs;
- 10 litre twin-supercharged v8
- 1850 hp = 1425 kw
- 1700 lb ft = 2305 nm
- Est top speed inxs of 440kmh
- Cost, a mere US$400,000
Looks ok, definitely tough.
imagine sitting at the lights next to....anything really.
i want one.
anyway i just thought I would show this as it is leaps and bounds above everything else i have seen.
www.vectormotors.com
  • Replies 48
looks like a NSX rear mixed with a 98 Camaro front wearing Supra headlights.
Been a while since they announced it though. like 2 years.
the styling 'revisions' just get more and more wacky
this was the high point i reckon (this was back when Atari pwned the console market :) )
yup, with you on that one brother. I can picture myself cruising along in that thing listening to some a-ha, take on me, or perhaps some nik kershaw as I'm on the way to my board meeting at compu global hyper mega net.
ahh, why can't I go back to the 80s?
while at a party, do you ever wonder why no one wants to talk to you?
i converse with many a party goer. cheers
LULZ!
you definately wouldn't find any tech company with 'net' in the name to be on the board of back in the 80's
The R35 and veyron were many a year in the making. I hope this one goes ahead. Assuming structural integrity and quality engineering and build, I would have thought $400,000 US to be a bargain.
Does anyone know whether the Joss (spelling?) is making it to production, haven't heard anything for a while.
Ah well, if 300ZX lights are good enough for Lamborghini to wear, then I'm sure Supra lights are good enough for Vector. Plus they'd already be DOT approved and tested etc so good to sell globally.
LULZ!
well we were very cutting edge back then. think cut com, or slash co. we also wore very, very thin ties.
what can I say? except:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
