hey guys few pars for sale , im in sydney & happy to send stuff interstate.
*left & right complete doors , blue color $200 each
*left & right front gaurds , blue color $120 each
*dashboard skin $80
*few dash buttons & stuff let me know what you want
*rear cradle complete minus diff $400
*fibreglass vented bonnet (damaged) can be repaired $100
*aftermarket front bar $300
*aftermarket sideskirts $200
*steering wheel $50
*rear lowered standard shocks & springs $80
*front windscreen $100
*rear wndscreen $100
ADDED ITEMS
*3" Cat back mandrell bent exhaust system including catco cat. $400
prices dont include shipping, ill get some pics up soon.
cheers
sam.
Edited by DRIFTMOB
https://www.sau.com.au/forums/topic/203167-r33-gtst/
*dashboard skin $80
*steering wheel $50
*rear parcle shelf $50
cheers
sam.
Im interested in the passenger side door mate. In good condition?
https://www.sau.com.au/forums/topic/203167-r33-gtst/#findComment-3610466
