G'day
My question is about the silver 100000kms service sticker that is on the black belt cover on the front of the engine.
Does this mean it has had the service or needs it?? Im looking to buy an R33 GTST with 71000kms on it and it has the silver sticker. Could this suggest it has more kms then on the clock or do most imports get the 100000kms service upon arrival to Aus??
Any insight would be much appreciated.
Cheers
Steve
https://www.sau.com.au/forums/topic/203280-100k-km-service-sticker/
if the sticker has a hand written odo reading on it then a 100k service has been done on it. if it has 100k that is printed then it is a reminder to do it.
to better check if things have been done and wound back check to see if there is any signs of sticker outlines that may suggest the 100k service sticker has been removed previously.
as with all the numerous threads about what to look for in buying a skyline...check wear/condition of interior and engine to match odo reading, do a compression test and all the other usual stuff. check to see if wires have been hacked and so on.
Ok thanks guys,
any other comments about the sticker post 'em up.
Would an NRMA check be good enough to determine whether the car is in order in regards to compression tests and what not??
Thanks
diferent places will do different things.. mainly,
gearbox, engine, diff oil
power steer, brake and clutch fluid flush
wheels bearings
timing belt
radiator hoses
brake pads or rotors
thats some of the things that may be done...
and i have heard alot of japs do the 100,000km service every 50,000. Cause usually u service it say 5000km or 6 months... but a 100,000km service is done say every 100,000km or 6 years.. and they may only get 50,000km on it in that 6 years..... if u ge what i mean
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
