Gday guys, I have just finished fitting a set of tein coil overs into my R34 GTT. Went for a drive and noticed a knock from the rear.
I just went over all the nuts n bolts to make sure they are tight and everyting is.
Just wondering if anyone has had something like this before and knows what it could be??
Thanks guys!
https://www.sau.com.au/forums/topic/203557-coil-overs/
Ok done a bit more reading.....
When I fit the new coil overs I didnt refit the metal plate that was between the strut and the body in the rear as the new ones are damper adjustable so didnt really want the adjustment screw being covered up by it!
Could that cause the knock?
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3608935
<br />Nah the boots empty. I guess ill just have to keep playin around with them until i find what it is!<br />
<br /><br /><br />
is the suspension brand new or 2nd hand?
when you jack the car up, can you move the rear wheels up and down easily? i had this problem, i could just move the wheels up and down on the shocker. i had to get it refilled
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3609201
They are 2nd hand....only done 10,000km tho supposedly! I put the metal plates back in the rear, (the ones that go between the strut and the body) and it hasnt really made any difference. Bugger.
Im hoping that the shocks arent stuffed in them already!
sorry forgot to mention daz, i checked for movement with the car raised and there is none.
thanks for your help so far guys
Edited by jase-r34
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3609504
you said they were new..ha
well if theyre deff second hand then that knocking will most probably be your pillowtops. they are worn. i have used teins and my right rear and front knock over rough bumps. not much you can do really except replace the tops. when your in the back seat or boot jump up and down to work the suspension on whichever side, you should be able to hear the knock then.
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3610243
Thanks for that nismo, I was actually thinking about suggesting if anyone thought that might help, but thought i'd look like a total knob hahaha.
Ill give it a go and let you know what happens!
The thought also crossed my mind that the noise could be normal as i've never used coil overs in any of my cars before!
Cheers for all the help guys!
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3612574
Ok, jacker her up and gave the strut tops a good old spraying with WD40 and took it for a run....no difference.
Oh well looks like im not going to get out of it that easily! should have known hahahaha
Thanks for your suggestions tho guys!
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3617798
the centre nut on the top of the shock may not be tight enough, tighten it right down. There will be a way to hold the dhock body from rotating while you do (allen key or slotted for a spanner somewhere on the shock body
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-3618112
  • 1 year later...
I am gaving the same issue with my 2000 Stagea.
Car was imported with Teins and is getting worse. Rears are really bad and giving me the S*its. Have taken to local suspension shop and they have no idea.
over speed bumps they are smooth, only over sharp bums they are knocking.
Will keep track of this topic lol
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-4801292
my brand new D2 coil overs knock in the front the odd time if i hit a hard or deep bump, but for mine its a knock being caused by the shock 'topping out' on its recoil...sounds rough but i dont think its hurting anything
https://www.sau.com.au/forums/topic/203557-coil-overs/#findComment-4801492
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
