  • Replies 327
Posted Images
Not going to work for me as I have entered the Powercruise 12 which is on the same date as this dyno day. Oh well, may be on the next one.
:D
Good luck at the powercruise!!!
Expecting a good result on the dyno?
im in for sure :banana: this will be my first dyno day yea!!!!! my car and turbo is stock exept for the exhaust... so yea i wont expect much but it would be nice just to see what it does have now and when i put the mods on to see what it pulls at the end of the year.....this will be great see you guys there
