  • Replies 53
yep thats what ive done =]
lol i just looked at ur user name and i had to look at it 3 times coz i thought it said c*cksmoker. dont take that the wrong way, im actually a fan of dosing (i drive a VL...)
below your avatar and name it says you have an N/A vl? :D
didnt realise you could doooossse!!! in a N/A?
Edited by jake33
I'm confused, if it measures the air twice, it would put more fuel in and run rich for a second and the typical atmo bov pop would be seen. Which is what happens. My car has not stalled once and appears to be getting better performance as there seems to be a little less lag.
I'm also confused about what people have against this noise. I will admit, I have left the standard airbox on but have taken the snorkel of so the noise is muffled but still is quite audible.
Is it because skylines are seen to be more classy than vl turbo's and should therefore go about being a performance car quietly?
Fair enough, then what is everyone's though of a gtr going around dosing its head off, becuase I was looking at getting a pod setup.
I have also thought of only blocking one of my bov's, this seems like a good idea as less air is being wasted to the atmo, yet less air is being sent back to the turbo's so the bearings will be less stressed. Win Win I think.
And yes I have though af reinstating a plumb back setup.........but where's the fun in that!
why the hell is that flutter so high pitched? like a gay canary?
i no likie. sounds weak and girly, like a barina with frangipani's on the rear window :D
my car does some sort of flutter, when lifting off the throttle quickly. it certainly wasnt by design or intention. but its far less irritating than that. much quiter. and alot deeper. more purposeful sounding.
(aftermarket plumbed bov set to medium spring setting. fmic. pod)
Had atmo BOV on my lancer when I was 18. Had a 4G61T engine. I thought I was cool. Times changed. Dose is not cool uleh. Now my 2 stock valves make enough noise for me. Im more interested in gettin my turbo spool as loud as possible. Thinkin a big single snail
dosing, LoL for people who take 5minutes to change gears and need something to fill in time.
ROFL thats about it, aint it.
nuff said
Edited by r33cruiser
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
    • What sold me on Trailer Park Boys is this scene: Great stuff, just stay clear from the new Netflix production.
