STOLEN: Autech Tsukada S13 Circuit/Drift Car - Stolen From Just Jap
News just in.
The Supra involved was a 1996 model in Silver and was stolen this morning at 11:30am.
We have been advised that the Supra has sideswiped another car in Hurstville and taken off.
It is now being chased by Police.
The theif that started and stole the S13 had a jacket around his head to mask his identity.
  • Replies 62
News just in.
Im pretty sure i know where the supra lives/lived
The Supra was stolen, but regardless please phone us mate if you think you have some info that may help and speak to either myself or Darron in the shop.
Many thanks.
We are now offering a $3000 no questions asked reward, for the safe return of the S13 intact.
Again, thanks to all of you who are keeping an eye out!
I just wanted to say, For everyone who moans and groans about the cops they seem to be doing a damn good job on this case!! By how its going id say you'll have your car back.
If it pops up in Orange I'll follow it :(
good luck lads, I'm sure the cops are treating you well, I mean you sell the products that get them the revinue from all those defect tickets! i kid i kid.
I hope its found, obviously a few dickheads with a thought out idea... hopefully not much more brains from there.
OMG! Sutherland shire is a theft capital at the moment!
Honestly cant believe they took it from the car park at the door!!!!!!!!!
They must have desperately wanted that car to grab it from there
Any update on this? Have they caught up to them? Hope you get you car back mate.
Cant believe they took it out if the carpark. they mustve known of the cameras tho...
We are working through the footage.
We have 14 security cameras around the shop and factory monitored 24/7 so its only a matter of time.
Front door. Broad daylight. Hotwired. Two stolen cars? Someones been watching too many heist movies.
I personally hope you get it back in one piece and i hope also that noones going to try some vigilante shit trying to get the reward.
Oh and Lingering sole, lighten up on the crippling will you? Over the top.
Not over the top enough..stupid thieves, I wouldnt feel bad if some thing happened to them
hoping someone - ANYONE - ends up as a quadraplegic is over the top, sorry.
Lowlife thief or not.
And anyway, Im sure Just Jap is fully covered on insurance so theyll just get a cheque cut for them and do it again, case closed. Right Richard?
Edited by m3gtr
yeah I agree. no one really wants to see anyone crippled over a car theft, even as frustrating and dissapointing as it is.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
