Hey guys,
i'm in a bit of a weird mood today so bare with me.... :D
I just want to thank everyone on this site who has actually given me the time of day and listened to me. (which is basically everyone)
I want to give special mention to Doof, Paul (NSA11N), and anyone else that has helped me. And before anyone asks no i am not gay! It just re-installs my faith in the import community because alot of people (mainly the ones NOT associated with a forum) are arrogant and think they are better than everyone else. And they are the ones that give us a bad name.
So yeah thanks everyone who has helped me with all my tricky questions, and don't worry there'll be heaps more for you to answer. :worship:
You all have absolutely AWESOME cars! i envy you all!
Hopefully one day i will have a car that is worthy to sit next to you all. :D
Cheers
Nick
You can still come to any event !! shouldnt think your car isnt worthy enough!!!
I hope to see you at an autosalon, or at any event soon!! ...
  • Replies 44
haha your funny jess.....
you haven't seen my car lol
Awww I dont need to see it..
I'm sure it has loads of character..
Does it run?
yeah it does run...barely...with a lot of dodgy parts
and if by character you mean scratches and bad paint...then yeah its got heaps :wave:
well.....
while your asking.... a Z tune and a Ferarri F430 Scuderia would be nice :)
apart from that...nothin..my intentions are honest
Mmmm :P I'm still checking my wallet just in case :P
I can afford to give you a nice neat z but thats all the budget will allow...enjoy
there's not very many gracious people on this site :D
i would've thought when a fellow member says thank you for they're help...the least they can say is your welcome...
and just because i made special mention of a few people..i'm thanking EVERYONE on here
you're welcome dude :D
i dont think i helped you though, but i'll take credit where credit is unclaimed.
btw, is this thread inspired by oprah? dr phil? the uniting church? or just an extra helping of ecstacy?
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
