Hello
I have to replace my stock injectors with another set of stock injectors.(one is not working correctly and the rest are soon to die, Nissan checked it for me) I have all of the parts but was wondering if this job is a not so hard one to do by someone who has never changed injectors before. My friend is going to help(he is a mechanic but not sure if he has changed RB20 injectors before.)
I want to do it but I found out that I have to take off the penum, intake manifold to do this. And I have to unscrew the cable that controls the revving of the engine(next to the throttle body).
Is this a easy job? Help please
https://www.sau.com.au/forums/topic/203917-changing-injectors-on-a-rb20-det/
No offense intended, but by the sounds of it i would pay someone to do it, it would be fairly cheap, and there are a few traps for new players. Just make sure new injector seals are used, and get the injectors cleaned before they go in.
You do not have to remove the intake manifold to change the injectors...i didn't have to when mine was done...the rail unbolts and it all comes off at one go...
I don't have to remove the intake manifold? How do I do it? I see the rail but it looks as if I have to take off the intake manifold, and Nissan told me I have too. Thats why I have gaskets for the intake manifold and penum. I am in Japan so it came from the horse's mouth. But if there is a way I can do it please tell me
I have also changed the injectors in an rb20det. I didnt have to take the plenum off either.
You just have to remove the cooler pipe going to the plemun and a few vacuum hoses and then unbolt the fuel rail.
When you replace the injector seals, makes sure they are genuine nissan ones because the ones that Mr Injector Cleaning Man sells you are slightly smaller.
You could also pay someone around $250 for them to do it. Thats how much they were going to charge me.
I will try that thank you. Oh I have the replacement set of injectors but they are on a rail already. I have all of the replacement seals but was wondering since these are already on a rail, should I just take out my old injectors, rail and all, and just put in the replacement injectors with the rail they are all ready in?
They are the correct injectors
Edited by 335
  • 4 months later...
i know this is a few month old but how exactly do you get the injector out. I have the fuel rail with injector in ti sitting on a table and no idea how to remove the injectors. Do I twist and pull or do I do unscrew or what? I tried pulling but nothing much happens, I also tried unscrewing, but nothing much happened either.
once everything is unbolted the fuel rail pulls out easy enough.. the injectors are quite hard to remove tho from the rail i was using a screwdriver to lever them out but than found a small socket n a hammer while having sum1 hold the rail to be much easier.. but your probally not going to want to reuse those injectors :blush:
a small tip tho when undoing the screws that hold the capping onto the injectors get a philips head screw driver that fits into them well and give them a pretty hard hit with the hammer to make undoing the screw a little easier... then get a vice grip lockd onto the top of the screw driver n push down as hard as you can n turn with the vice grips.. then throw away those gawd awful screws and get some M5x16mm high tensile bolts from bunnings =)
if you do manage to round out a screw just hacksaw blade in a slit n hammer the corner with a flat bladed screw driver until the seal breaks then its easy to turn
other than that its pretty easy theres a DIY guide here for a 25, they have pretty similar intakes so shouldnt be to different
http://www.skylinesaustralia.com/forums/In...lling+injectors
just dont go dropping the plastic spacers between the fuel rails and the manifold.. i was warned and still managed to drop 2 so pull them out before u move the rail
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
    • Hmmm, interesting. Makes me wonder whether there is bias as well. It's the cheapest fuel, so it is used for all kinds of ill-maintained shitboxes which are bound to have issues regardless. Nicer cars tend to require higher octane rated fuel and can't use it anyway. FWIW, the official NSW E10 facts page is decent.
