I am thinkin of buying a N1 oil pump to replace my RB25DET pump in my RB30DET, it has around 360+ rwkw and I keep hearing shock storys of them breaking into pieces on the drag strip or sometimes out of the blue.
Is there a reason for this ? I do have a crank collar on my crank (stupid thing caused all sorts of drama's which destroyed my previous crank) but anyway....
The old RB25DET pump has done me well and still works but its had close to 300,000 km's on it so i am thinking its time to change it and cannot really afford a Nismo or JUN pump at this time.
Anyone have any luck with these pumps ? is it just that they dont like the rev limiter too much ???
Anyways who has used them or is using them where they are working well? is that talk all just bullshit or should i just keep the 25 pump ?
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/
what setup do you have in yours? what are you like with the rev limiter? i need to use the rev limiter because sometimes its just sooo hard to catch the revs before hitting it, some gears its near impossible.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616168
you will have no issues with the N1 if you bottom end is all balanced well with light weight good quality rods .
i think all the talk about N1 smashing drives is because ppl put heavier aftermarket rod's in and try and rev them then the harmonics really start to happen and the weakest link is the oil pump gears.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616233
AFAIK the only difference with the N1's is the different casting and the pressure relief valve uses a higher rated spring.... In other words it wont actually flow any more, It will just hold pressure longer before the relief valve opens at higher rpm.
The same can be acheived on the RB25/26 pumps by removing the relief valve and installing an extra washer. My engine builder informed me that a 1mm washer will bump pressure up approx 5psi.
Edited by MintR33
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616378
The gears of the N1 oil pump are made from a harder grades metal then std , they also have a lesser amount of teeth on the oil pump drive gears allowing the pump to flow more and the backing plate has a 8 bolt pattern instead of the 7 , its also thicker .
Not sure about if you are able to measure harmonics. I am sure there would be some expensive machine out there that would measure harmonics.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616454
Thats interesting SATO are we both talking about N1 pumps, not getting confised with Nismo?? both my engine builder and SK are saying the same thing, heres a direct quote from SK
Hi Merli, having measured quite a large number of RB pumps what I have noted follows;
*N1 GTR pumps run at higher oil pressure but the same flow as standard GTR pumps.
*I have "adjusted" the pressure relief valve on a standard GTR pump and achieved the same oil pressure as an N1 pump
*N1 pumps are the same dimensions as standard pumps therefore can not flow any more oil than a standard pump does at the same rpm.
*HKS GTR pumps are thicker across the impeller, therefore flow more oil at the same rpm.
*HKS GTR pumps have adjustable oil pressure, so you can run higher, lower or equal to strandard pressure but at higher flow rates.
On our circuit race cars we always increase the capacity of the sump and fit wings and one way baffles. Anybody who spends any time on a circuit should do the same.
Hope that helps
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616511
Heres a more recent reply from SK re N1 oil pumps:
Absolutely correct Chris, all the N1 pump does is run at a higher relief pressure. Jun, HKS, Trust and a couple of others make pumps that actually flow more. I don't know what prices you get over there, but I can buy a complete Peterson 4 stage dry sump system for less than Jun want for a replacement pump. Both still require sump mods, so it pretty easy to understand why I go for the dry sump option on the race cars. On the road cars I simply fit a stronger pressure relief spring to the standard GTR oil pump, then it's the same as an N1 pump, costs about $2.
:D
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616525
My limiter is set to 6800rpm but I never hit it due to the small assed turbo on there (rb25 turbo) it falls over about 5800rpm and drops down to 90hp by the limiter. I just make a point of shifting up ~5500rpm.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616775
There is a further complication, there are 7 "standard" RB26 oil pumps available from Nissan;
1 .R32GTR Early
2. R32GTR Late
3. R32GTR V Spec
4. R32GTR N1
5. R33GTR S1
6. R33GTR S2 + V Spec
7. R34GTR all models
#1 is not the same as any other RB26 pump, plus it has the narrow drive flange, and it is the same as RB20, RB25 and RB30 (late)
#2 is the same as #5
#4 is the same as #6 and #7 except that it has a higher pressure relief spring
I have yet to see/measure a guaranteed #3, although I suspect it is the same as #4
So when I say a "standard" RB26 oil pump is the same as N1 oil pump except for the pressure relief spring, I am not talking about #1. That should be obvious as #1 has the narrow drive flange whereas #2 and all subsequent RB26 oil pumps have the wide flange drive.
Thinks that's complicated, but wait there is more. Don't expect to be able to go into a Nissan dealer and order #2, #3 or #5 as their part numbers have been superceded by #6 and subsequently #7.
Cheers
Gary
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617366
We don't "measure" harmonics, we feel them. The gear lever is not bad for that.
On the engine dyno, you can feel it through the flooor.
Cheers
Gary
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617380
when you say you cant afford a JUN pump, what have you been qouted for it? and what have you been qouted for a nissan N1?
i usually pay around 70000 ($750) yen plus shipping for a JUN 1013M-N001G unit. RRP is 98000 or $1050 worst case..
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617644
RB25 oil pumps are 500 from nissan, so you'd be silly not to pay a few hundred more for a jun 26 pump... tho that said i cant understand how they are so expensive.... a water pump has the same sort of casting required to make it... the only expensive part i can see being is the gear set... but stil!
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617682
    • Clutch is a spec brand, new clutch system,( PP, flywheel, friction disc, etc. pull type) installed 100 miles ago, with no problems.
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drove beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
