I am thinkin of buying a N1 oil pump to replace my RB25DET pump in my RB30DET, it has around 360+ rwkw and I keep hearing shock storys of them breaking into pieces on the drag strip or sometimes out of the blue.
Is there a reason for this ? I do have a crank collar on my crank (stupid thing caused all sorts of drama's which destroyed my previous crank) but anyway....
The old RB25DET pump has done me well and still works but its had close to 300,000 km's on it so i am thinking its time to change it and cannot really afford a Nismo or JUN pump at this time.
Anyone have any luck with these pumps ? is it just that they dont like the rev limiter too much ???
Anyways who has used them or is using them where they are working well? is that talk all just bullshit or should i just keep the 25 pump ?
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/
what setup do you have in yours? what are you like with the rev limiter? i need to use the rev limiter because sometimes its just sooo hard to catch the revs before hitting it, some gears its near impossible.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616168
you will have no issues with the N1 if you bottom end is all balanced well with light weight good quality rods .
i think all the talk about N1 smashing drives is because ppl put heavier aftermarket rod's in and try and rev them then the harmonics really start to happen and the weakest link is the oil pump gears.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616233
AFAIK the only difference with the N1's is the different casting and the pressure relief valve uses a higher rated spring.... In other words it wont actually flow any more, It will just hold pressure longer before the relief valve opens at higher rpm.
The same can be acheived on the RB25/26 pumps by removing the relief valve and installing an extra washer. My engine builder informed me that a 1mm washer will bump pressure up approx 5psi.
Edited by MintR33
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616378
The gears of the N1 oil pump are made from a harder grades metal then std , they also have a lesser amount of teeth on the oil pump drive gears allowing the pump to flow more and the backing plate has a 8 bolt pattern instead of the 7 , its also thicker .
Not sure about if you are able to measure harmonics. I am sure there would be some expensive machine out there that would measure harmonics.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616454
Thats interesting SATO are we both talking about N1 pumps, not getting confised with Nismo?? both my engine builder and SK are saying the same thing, heres a direct quote from SK
Hi Merli, having measured quite a large number of RB pumps what I have noted follows;
*N1 GTR pumps run at higher oil pressure but the same flow as standard GTR pumps.
*I have "adjusted" the pressure relief valve on a standard GTR pump and achieved the same oil pressure as an N1 pump
*N1 pumps are the same dimensions as standard pumps therefore can not flow any more oil than a standard pump does at the same rpm.
*HKS GTR pumps are thicker across the impeller, therefore flow more oil at the same rpm.
*HKS GTR pumps have adjustable oil pressure, so you can run higher, lower or equal to strandard pressure but at higher flow rates.
On our circuit race cars we always increase the capacity of the sump and fit wings and one way baffles. Anybody who spends any time on a circuit should do the same.
Hope that helps
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616511
Heres a more recent reply from SK re N1 oil pumps:
Absolutely correct Chris, all the N1 pump does is run at a higher relief pressure. Jun, HKS, Trust and a couple of others make pumps that actually flow more. I don't know what prices you get over there, but I can buy a complete Peterson 4 stage dry sump system for less than Jun want for a replacement pump. Both still require sump mods, so it pretty easy to understand why I go for the dry sump option on the race cars. On the road cars I simply fit a stronger pressure relief spring to the standard GTR oil pump, then it's the same as an N1 pump, costs about $2.
:D
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616525
My limiter is set to 6800rpm but I never hit it due to the small assed turbo on there (rb25 turbo) it falls over about 5800rpm and drops down to 90hp by the limiter. I just make a point of shifting up ~5500rpm.
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3616775
There is a further complication, there are 7 "standard" RB26 oil pumps available from Nissan;
1 .R32GTR Early
2. R32GTR Late
3. R32GTR V Spec
4. R32GTR N1
5. R33GTR S1
6. R33GTR S2 + V Spec
7. R34GTR all models
#1 is not the same as any other RB26 pump, plus it has the narrow drive flange, and it is the same as RB20, RB25 and RB30 (late)
#2 is the same as #5
#4 is the same as #6 and #7 except that it has a higher pressure relief spring
I have yet to see/measure a guaranteed #3, although I suspect it is the same as #4
So when I say a "standard" RB26 oil pump is the same as N1 oil pump except for the pressure relief spring, I am not talking about #1. That should be obvious as #1 has the narrow drive flange whereas #2 and all subsequent RB26 oil pumps have the wide flange drive.
Thinks that's complicated, but wait there is more. Don't expect to be able to go into a Nissan dealer and order #2, #3 or #5 as their part numbers have been superceded by #6 and subsequently #7.
Cheers
Gary
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617366
We don't "measure" harmonics, we feel them. The gear lever is not bad for that.
On the engine dyno, you can feel it through the flooor.
Cheers
Gary
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617380
when you say you cant afford a JUN pump, what have you been qouted for it? and what have you been qouted for a nissan N1?
i usually pay around 70000 ($750) yen plus shipping for a JUN 1013M-N001G unit. RRP is 98000 or $1050 worst case..
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617644
RB25 oil pumps are 500 from nissan, so you'd be silly not to pay a few hundred more for a jun 26 pump... tho that said i cant understand how they are so expensive.... a water pump has the same sort of casting required to make it... the only expensive part i can see being is the gear set... but stil!
https://www.sau.com.au/forums/topic/203987-n1-oil-pump/#findComment-3617682
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
