R33 Chop ...rims, Colour, Lowered =]
Yeah well today second day back in school yr 12 =[
i got pretty bored during my study period
so i came up with this
i like the colour but suspension bit tooo low to be believable.
what you all think??
Original
MY one =]
Edited by blk_sz
https://www.sau.com.au/forums/topic/204068-r33-chop-rims-colour-lowered/
lol, i agree with the lowering, mayb a tad low, maybe make the color a tiny bit darker, its jus that the reflections on the original look dark, but on the new one look a bit light, jus to fit in wit the surroundings, other than that, good job on the color change :(
  • 1 month later...
Hi All,
What program did you use for the mods? I've attached two variants to the paint job + Lowering. First one is a metallic purple and the other a blue/ Purple pearl. I have also re-tweaked the lowering and the rim size. Let me know what you think.
that looks phat different colour funney thing is my car was that low when i bought it nothing but a hassel getting in and out of places. Pluss i was defected good on ya newie police defecting me 2 days before the new springs came
  • 3 weeks later...
Original
MY one =]
Sup, what program did you use to do this, looks wicked!
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
