hey guys went to calder last night and the best time i ran was a 13.92 @ 106.5mph. my 60 ft sucked big time.
im running 220rwk, stock suspension lowered with jjr pineapples and 265/35/18in street tyres ( hankooks).
dosent matter what i done whether i rode the clutch or took off hard or even slow soon as i hit boost id spin the tyres.
soon as i hit second though i felt the pineapples work and damn the car started flying!! but i have to sort this problem out.
if i went slow my 60ft would suffer even more.
my 60ft'rs were avaraging 2.39- 2.51.
reccommend me a good street tyre setup and anything else that could help me. i spoke to my tuner and he told me my mph was good for a high 12.
need some help!!.. please
thankyou
https://www.sau.com.au/forums/topic/204121-just-couldnt-get-the-power-down/
  • Replies 142
Posted Images
What Tyre pressures were you running?
Its always going to be hard to get 18s to bite.
I would also suggest new shocks if you dont have them already.
There is also a good thread by Sydneykid about changing the angle of your sub frame for more grip off the line.
ive already done that with the pineapples.
tyre pressures were at 28 psi. still want them streetable
Edited by R33GOD
Forget messing with the subframe beyond the pineapples which you've already fitted. Ditch the 18's and fit up 255/50/16" MT ET Street Radials and practice more.
yes mate i understand what your saying but i want to run the same setup i do all day long. my aim is to achieve a high 12 second pass with my 18's
In that case, just practice. You'll need a 1.80-1.85 second 60' time to dip into the 12's for that mph. Incidentally, 220rwkw is not = 106mph.
what exactly are you getting at mate?
That 106mph is showing less hp than the dyno sheet indicates. That's all. Practice, practice, practice and get your short times down to 1.8x and you stand a chance of running in the 12's.
Why dont u try a two stage boost, its obviously it causing the issue, 10 psi into 14psi.. Ive got the same power and have no problem dropping the clutch and managing the tyre spin.. Back off and plant it..
Edited by DECIM8
tony, get urself a set of stock skyline rims, with 225's on them some high profile and flatten them to around 15 - 18 psi, worked for me, but i was running 20 kw less than you back then.
You need something with a bigger sidewall than a 35 profile, to hook up off the line.
These are the points
1. You wont ever go anywhere near 1.7x-1.8x 60fts with 18's and street rubber.
2. The Hankooks arent the best tyre either (i assume K104s?)
3. You dont have 220rwkw. More like 190 or so, so you MUST have a super low 60ft time to compensate for the power you dont have.
As 2rismo said, you dont have 220rwkw with 106mph.
I was running consistent 12.9 @ 111mph with 220rwkw, and 1.9x-2.1x 60ft times.
The tyres i used were Dunlops 3000A's - 225/16 @ 20psi
This is in a HR31 which has the IRS geometery of uselessness, i still managed with lots of practice. :banana:
I had easily rattled off 50 passes without touching the car setup over about 6-7 meets before i nabbed regular 12.9X-13.0X times with the tyres and power i had
So you need better tyres/wheel size and drop some air out of them and go practice.
a VERY high 12 can be done with 190-200rwkw no problem. But not with your current setup, you will never get close im afraid.
    • I sense an out of control build thread coming up lololol. That 450kW goal will end up being 600 to 700kW LOL.
    • Nice, thanks for sharing your progress....that's a pretty long list you are putting into it!
    • Decided to upgrade my pressurised plastic coolant expansion tank for a fancy pants alloy version The OEM versions can get brittle, even the new plastic one I got when I first got the car is a starting to show signs of "stress" I wasn't cheap, but it is basically unbreakable
    • Morning all, I have an RB25DET Neo that's in need of a rebuild. Will need new pistons etc due to detonation damage. Would anyone be able to recommend a shop in Southeast Queensland who I could bring my long motor to for a rebuild? Just want someone who knows RBs and whos built a bunch of them before. TLDR - recommended engine shops for RB rebuild.
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
