  • Replies 142
Posted Images
very strange. i went for a 30 minute drive earlier. just cruising and every gear change felt shakey.
when i got home i could smell clutch really bad. made me sick. whats goin on with this damn car!
want to find this problem before i buy another clutch and stuff it up too.
Edited by R33GOD
Hey, sorry to hijack the thread but ive been wanting to know about my time slip for a long time now.
My best time so far has been a 12.54@111mph on MT ET Streets. My 60' was 1.8.
How much power does this MPH indicate? The dyno says 270rwkw.
270rwkw should be up around 116-118mph mark easy
I agree, have had customer cars run high 11s with 1.7 sixty at 120mph with 280rwkw
111 - 220-230rwkw
18psi doesnt mean a lot of the tune is bone average and lazy - it wont make power :D
You should be in the 11's with 270rwkw IMO on MT's, or the very low 12's.
my mates R32 GTR pulls 240rwkw.
Now i would believe the figure as my car (GTT with cat back) pulled 161.2rwkw straight after it. (so the dyno is pretty close on what mine should be pulling, which i think proves his figure should also be accurate to a degree)
However it only runs 104mph best at the drags. (2wd mode)
So even with the power, if you cant make alot of use of it (his is HKS T45s) it seems it can effect your mph big time. It makes power like the faint line on the graph above!
Check out the following expertly produced dyno graph showing two cars each making 270kW.
Which car is quicker over the quarter mile?
p.s. fear my mspaint skills
:laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014: :laughing-smiley-014:
It only makes its power for a very very small amount of the time it's racing which apart from being fairly pointless is a good demonstration of what I was trying to say.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
